USAPhO 2009 F=MA exam #16, (angular frequency of a spring)
In summary, the problem involves finding the angular frequency of a system with two identical masses m placed on either end of a spring with spring constant k. After some reasoning and manipulation of equations, the answer is found to be √(2k/m) instead of the expected √(k/2m). This is because the center of the spring is stationary and each mass can be considered as oscillating at the end of half a spring. If the system is changed so that one end has a mass m and the other has a mass 2m, the angular frequency can be found by treating each mass as if it were on its own spring and using the equation √(ki/mi).
Agrasin
69
http://www.aapt.org/physicsteam/2010/upload/2009_F-maSolutions.pdf
Two identical objects of mass m are placed at either end of a spring of spring constant k and the whole system is placed on a horizontal frictionless surface. At what angular frequency ω does the system oscillate?
f = (1/2∏) √(m/k)
Some equation involving angular frequency and springs would help here...I cannot recall anything
This problem seemed to be more of a reasoning problem than a mathematical one. I tried manipulating the frequency formula. However, the answer doesn't even have a 2∏ term in it! This boggled me.
The answer is √(2k/m)
They ask for angular frequency ω, which is not the same as f. Hint: ω is measured in radians/sec.
Likes 1 person
Okay, I've done some googling and wikipedaing, and angular frequency is the magnitude of angular velocity (in general). For springs, and I would never have guessed this and I don't know how this was even made up, angular frequency ω = √(k/m). Wha...? How is that even related to the first definition of angular frequency?
Okay, that takes me a step closer. I understand why there are no pi terms. But it is still a reasoning problem. Why, when two masses are put on the two ends, does k get doubled? √(k/2m) would've been my most educated guess.
Btw I've edited the original question to include the link to the problem in case you want to see all the possible answers.
Frequency is cycles per second. Each 'cycle' has 2π radians, so ω = 2πf. (Not related to angular velocity.)
Hint: The center of the spring is stationary, thus you can consider each mass as oscillating at the end of half a spring.
Likes 1 person
So does it just turn into a system of two springs, each with spring constant k and mass m?
If it does, adding up their frequencies would get me 2√(k/m)
But I have a feeling I don't add up the individual frequencies to get the total frequency...
No. If you cut a spring in half what happens to its spring constant?
No, you don't add them! ("Total" frequency doesn't make sense.) The frequency of each mass is the frequency.
Likes 1 person
Thank you for your patience with me, Doc Al!
Yes, total frequency doesn't make sense, does it...
And, why, believe it or not, the spring constant doubles! So √(2k/m).
Now this question is resolved, but my knowledge of springs has been proven to be lacking. May I ask one question, just for the fun of it?
What if this system was changed so one side had a mass m and the other side had a mass 2m? Or 3m, 4m, etc.? Would it evolve into complex, ugly oscillations, or is there a simple, elegant answer for the new angular frequency?
Hint: Consider the center of mass.
Likes 1 person
The new spring constant k becomes (m2 / m1 + m2)-1k + (m1 / m1 + m2)-1k I believe.
Not exactly. Each segment of spring, measured from the center of mass, will have its own spring constant. While the spring constants are different, the frequency of oscillation, which depends on k/m, is the same.
Likes 1 person
Say one end is 3m and the other is m. The center of mass will be 3/4 down the spring length, close to the big mass. The spring constant on the big mass's side becomes 4k because the spring there is cut into a fourth. The spring constant on the other side is 4/3 k because the spring is 3/4 the original length. Adding these up, you get (16/3)k. The angular frequency is √(16k / 12m) = √(4k / 3m)
If I did the same process with a spring with 4m on one side and m on the other, the angular frequency would be
√(5k / 4m).
Am I correct? I see the pattern.
So far, so good.
Why in the world did you add them up?
Instead, treat each mass as if it were on its own spring. The ω for each mass is given by √(ki/mi).
Likes 1 person
Ohhhh I see. I thought in the first example we did (√(2k / m) we got the result by adding up the spring constants.
So the ω for each mass in the 3m&m example is √(4k / 3m). Still. After isolating both sides. Perhaps, then, what I did (adding up the total spring constant and the total mass) was okay in this case?
No, the result was gotten by analyzing each mass separately. Remember that you are asked to find the angular frequency at which the masses oscillate.
While it is interesting that [itex](k_1+k_2)/(m_1+m_2) = k_1/m_1 = k_2/m_2[/itex], I fail to see the physical justification for adding the spring constants and masses in this manner.
I think the expression for the angular frequency in all problems of this sort is ω = √( (M + m) * k / (M*m) )
FAQ: USAPhO 2009 F=MA exam #16, (angular frequency of a spring)
What is the formula for calculating the angular frequency of a spring?
The formula for calculating the angular frequency of a spring is: ω = √(k/m), where ω is the angular frequency, k is the spring constant, and m is the mass attached to the spring.
How is the angular frequency of a spring related to its period?
The angular frequency and period of a spring are inversely proportional to each other. This means that as the angular frequency increases, the period decreases, and vice versa.
What is the unit of measurement for angular frequency?
The unit of measurement for angular frequency is radians per second (rad/s).
Can the angular frequency of a spring be negative?
No, the angular frequency of a spring cannot be negative as it is a measure of how quickly the spring oscillates back and forth. A negative value would indicate that the spring is moving in the opposite direction, which is not possible.
How does the mass attached to a spring affect its angular frequency?
The mass attached to a spring directly affects its angular frequency. As the mass increases, the angular frequency decreases, and as the mass decreases, the angular frequency increases.
