USAPhO 2011 F=ma exam #12, (gravitational force, 3 body)
In summary: So in the two-ball system, the compressive force on each rod is just f. In the three-ball system, each rod is experiencing two compressive forces, one from each ball, so the total compressive force on each rod is 2f. Therefore, the correct answer is C, just f.
Agrasin
69
http://www.aapt.org/physicsteam/2012/upload/exam1-2011-1-3-answers_1.pdf
You are given a large collection of identical heavy balls and lightweight rods. When two balls are placed at the ends of one rod and interact through their mutual gravitational attraction (as is shown on the left), the compressive force in the rod is F. Next, three balls and three rods are placed at the vertexes and edges of an equilateral triangle (as is shown on the right). What is the compressive force in each rod in the latter case?
F = Gm2 /r2
In the first case (2 balls on one rod), the compressive force is 2*Gm2 /r2.
In the second case (3 balls, 3 rods, equilateral triangle), the compressive force can be measured by looking at one rod and the forces acting on it.
If you take the left-hand rod, there is a compressive force F on the rod, which would be there even without the triangle. Now, because of the triangle set-up, there are two more compressive forces working at angles of 30 to the horizontal. I need to add the vertical components of these forces to the original compressive force.
2* Fsin(30) = F
The additional compressive force due to the adjacent rods and ball is F. So, F(original) + F(due to triangle set up) = 2F.
2F is choice E. However, the answer is C, just F. How??
No. Consider the forces acting on one ball.
2* Fsin(30) = F
I was not able to follow your logic. You would do better to consider the forces on one ball, as above.
The force on one ball? F = Gm2 /r2 pulling it along one rod, and again F = Gm2 /r2 pulling it along the other rod, 60 degrees from the first.
Not entirely sure how you are using F there. Is it the F in the statement of the problem, or generic?
Anyway, there are four forces on each ball in the three ball system: two gravitational and two mechanical.
Do you understand that the compressive force in the two ball system is just Gm2/r2?
Likes 1 person
Okay, big F is generic force.
Little f is the compressive force experienced by a rod in a two-ball system. Why would f be just Gm^2 / r^2? Wouldn't it be twice that because there are two balls squeezing, each of which experiences a force of Gm^2 / r^2 ?
Two gravitational and two mechanical forces on each ball in the 3-ball system? So each gravitation F is Gm^2 / r^2. Each mechanical (exerted in opposite direction by rod) must be the same because the ball is at rest.
...How do I get to the answer from there?
Imagine a spring with a constant of 500 N/m. To compress it by one centimeter, what force must you exert on each end?
Hint to get the answer: Consider all the forces acting on each ball.
Let's take the most complex situation: a massive object subject to a set of forces, undergoing acceleration. But to simplify it a little, it's a rod under compression. The compressive force will not be the same along its length. If you imagine cutting the rod at some point into two parts, the compressive force at that point is the force each part exerts on the other.
For a massless rod, the compressive force in it is therefore the force exerted on each end (the two forces are necessarily the same), not their sum.
That is indeed the right answer. The gravitational force ball A exerts on ball B is balanced by the force the rod joining them exerts on B. It's sort of obvious, but it doesn't hurt to go through the actual equations and see it emerge.
Thanks guys, that makes sense. The compressive force is just f = Gm^2 / r^2.
FAQ: USAPhO 2011 F=ma exam #12, (gravitational force, 3 body)
How many bodies are involved in the F=ma exam #12 for USAPhO 2011?
The F=ma exam #12 for USAPhO 2011 involves 3 bodies.
What is the concept being tested in this question?
The concept being tested in this question is gravitational force.
Can you explain the scenario described in the question?
The scenario described in the question involves three bodies with masses m1, m2, and m3, positioned in a line with m1 between m2 and m3 and a distance d between each body. The question asks for the gravitational force exerted on m1 by m2 and m3.
How can I solve this question?
To solve this question, you can use the formula for gravitational force: F = G(m1m2)/d2, where G is the universal gravitational constant (6.674 x 10-11 N*m2/kg2). Plug in the values given for m1, m2, and d to find the force exerted on m1.
How can I improve my understanding of gravitational force for this type of question?
To improve your understanding of gravitational force for this type of question, you can practice solving similar problems, review the formula for gravitational force, and make sure you understand the concept of gravitational force and how it applies to multiple bodies. You can also seek help from a teacher or tutor if needed.
