MHB Use Algebraic Manipulation Part 2
  • Thread starter Thread starter shamieh
    Manipulation
The discussion focuses on using algebraic manipulation to demonstrate that the sum of minterms for three variables, represented as $$\sum m(1,2,3,4,5,6,7)$$, equals $$x1 + x2 + x3$$. Participants express confusion over the meaning of the summation notation and how to derive additional terms in the expression. Clarification is provided that the summation excludes the term $$\bar{x}\bar{y}\bar{z}$$, leading to a simplified form of the equation. The conversation emphasizes the importance of understanding foundational concepts and definitions in Boolean algebra to solve such problems effectively. Overall, the thread highlights the challenges of algebraic manipulation in the context of truth tables and minterm notation.
shamieh
Use algebraic manipulation to show that for three input varibles x1, x2, and x3
$$\sum$$m(1,2,3,4,5,6,7) = x1 + x2 + x3
So far all I have is a truth table with 8 rows because I know 2^3 = 8 (starting at 0 of course, just assume the list I prepared on here is starting at 0 and not 1 - ending at 7.)
  1. x1x2x3
  2. 0 0 0 = 0
  3. 0 0 1 = 1 [x! x! x] +
  4. 0 1 0 = 1 [x! x x!] +
  5. 0 1 1 = 1 [x! x x] +
  6. 1 0 0 = 1 [x x! x!] +
  7. 1 0 1 = 1 [x x! x] +
  8. 1 1 0 = 1 [x x x!] +
  9. 1 1 1 = 1 [x x x] +
So how do we go from:
= $$(x1x2x3+x1x2x3+x1x2x3+x1x2x3)+ (x1x2x3+x1x2x3+x1x2x3+x1x2x3) +(x1x2x3+x1x2x3+x1x2x3+x1x2x3)$$ <-- WHERE do these extra FOUR terms come out of nowhere??Here is the final solution. Just don't know how they got the four extra terms OR how they got there...
= x1+ x3+ x2
I am lost in the dark...(Emo)
It's not clear to me what $\sum m(1,2,3,4,5,6,7)$ means. Is that
$$\sum m(1,2,3,4,5,6,7)=\bar{x} \bar{y} \bar{z}+\bar{x} y \bar{z}+\dots?$$
Are you summing all the terms except one? As you can see, I've changed your notation of $x_{1}, x_{2}, x_{3}$ to $x,y,z$, as they're much faster to type.
I think it is $\sum_{i=1}^7x^{b_2(i)}y^{b_1(i)}z^{b_0(i)}$ where $b_i(n)$ is the coefficient of $2^i$ in the binary expansion of $n$, i.e., the $i$th binary digit from the right, counting from $i=0$; $x^1=x$ and $x^0=\bar{x}$. Thus, \[\sum m(1,2,3,4,5,6,7)= \bar{x}\bar{y}z+\bar{x}y\bar{z}+\dots+xyz\]
So it's every term except $\bar{x}\bar{y}\bar{z}$?
The way I wrote it is exactly how I was given the question on my homework, as well as in the book. So I am just as lost as you Ach...Lol:confused:
Yes. Thus, both this DNF and $x+y+z$ are false iff $x=y=z=0$. In fact, I don't know what $m(b_1,\dots,b_n)$ is, but it seems that instead of $\sum m(b_1,\dots,b_n)$ one should write $\sum_{i=1}^nm(i)$ or $m(b_1,\dots,b_n)$.
Converting a DNF into a CNF is simple in principle: apply repeatedly distributivity of conjunction over disjunction, merge disjunctions of the same literal and remove disjunction with complementary literals (e.g., $x$ and $\bar{x}$). Unfortunately, a DNF with 7 conjunctions and 3 literals in each conunctions generates $3^7=2187$ disjunctions, most of which are vacuously true. We need a meta-argument in English about a formal derivation, which is a series of equalities consisting of applications of Boolean laws. It seems that it is easiest to still go through truth tables. If necessary, I'll continue later.
To be honest, I resent such remarks. I don't doubt that both the textbook and the homework statement used m(...), but I am sure that the textbook, as well as your instructor during the lectures, defined it earlier, probably gave several examples of this concept and discussed it in other ways. All it takes is going back and studying the theory before attempting to solve exercises, which in general is impossible to do without knowing the theory. If m(...) is indeed undefined, then you can not only complain to your instructor, but write to the textbook author, who will probably will be very glad to find this omission and will include it into later editions.
Hello, I'm joining this forum to ask two questions which have nagged me for some time. They both are presumed obvious, yet don't make sense to me. Nobody will explain their positions, which is...uh...aka science. I also have a thread for the other question. But this one involves probability, known as the Monty Hall Problem. Please see any number of YouTube videos on this for an explanation, I'll leave it to them to explain it. I question the predicate of all those who answer this...
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
