Use Remainder theorem to find factors of ##(a-b)^3+(b-c)^3+(c-a)^3##
The expression (a-b)³ + (b-c)³ + (c-a)³ simplifies to 3(c-a)(a-b)(b-c), indicating that the factors (a-b), (b-c), and (c-a) divide the expression. The discussion explores approaches to verify this factorization, including adding and subtracting terms and evaluating the expression when two variables are equal. Participants also seek clarification on the application of the Remainder Theorem in this context, distinguishing it from other mathematical concepts. Ultimately, the consensus is that the expression is zero when any two of a, b, or c coincide, confirming the identified factors.
chwala
Remainder theorem
My first approach;
##(a-b)^3+(b-c)^3+(c-a)^3=a^3-3a^2b+3ab^2-b^3+b^3-3b^2c+3bc^2-c^3+c^3-3c^2a+3ca^2-a^3##
##=-3a^2b+3ab^2-3b^2c+3bc^2-3c^2a+3ca^2##
what i did next was to add and subtract ##3abc## ...just by checking the terms ( I did not use Remainder theorem ):rolleyes:
=3abc-3a^2b+3ab^2-3b^2c+3bc^2-3c^2a+3ca^2-3abc##
##=3c(ab-ac-b^2+bc)-3a(ab-ac-b^2+bc)##
##=3(c-a)(ab-ac-b^2+bc)##
##=3(c-a)(a(b-c)-b(b-c))##
##=3(c-a)(a-b)(b-c)##
I need to check later on how to apply the Remainder theorem, any insight on this is welcome...
My second approach;
If##a=b## then ##f(b)=(b-c)^3+(c-a)^3##
If ##b=c##, ##f(c)=(a-b)^3+(c-a)^3##
If ##c=a##, ##f(a)=(a-b)^3+(b-c)^3##
If ##a=b## then ##(a-b)## will be a factor,
if ##b=c##, then ##(b-c) ## will be a factor,
If ##c=a##, then ##(c-a)## will be a factor. Therefore on taking product of the factors we shall have
##(a-b)(b-c)(c-a)=abc-a^2b-ac^2+a^2c-b^2c+ab^2+bc^2-abc## ... on multiplying both sides by ##3## we shall have,
##3(a-b)(b-c)(c-a)=3[abc-a^2b-ac^2+a^2c-b^2c+ab^2+bc^2-abc]≡(a-b)^3+(b-c)^3+(c-a)^3##
We observe it is quadratic for a, b and c and if any of two are equal it vanishes so it has factor (a-b)(b-c)(c-a).
say a=-1,b=0,c=1 it is 6 and (a-b)(b-c)(c-a)=2 so the coefficient is 3. In total 3 (a-b)(b-c)(c-a).
chwala said:
Homework Statement:: Use Remainder theorem to find factors of ##(a-b)^3+(b-c)^3+(c-a)^3##
Relevant Equations:: Remainder theorem
My approach;
Alternatively,
If ##c=a##, then ##(c-a)## will be a factor. Therefore on taking product of the factors we shall have##(a-b)(b-c)(c-a)=abc-a^2b-ac^2+a^2c-b^2c+ab^2+bc^2-abc## ...
##f(b)-(c-a)^3=(b-c)^3##
##f(c)-(a-b)^3=(c-a)^3##
##f(a)-(b-c)^3=(a-b)^3##
What do you mean by remainder theorem? The Chinese remainder theorem, Euclidean division, or something else?
One immediately sees that the expression is zero whenever two out of ##a,b,c## coincide. Thus all ##a-b\, , \,b-c\, , \,c-a## divide the expression. They are also pairwise coprime, so ##(a-b)(b-c)(c-a)## divides the expression. Finally, consider the degrees.
https://www.purplemath.com/modules/remaindr.htm
chwala said:
Ok, that is Euclidean division. You can consider the polynomial consecutively as element of ##\mathbb{Z}[a]\, , \,\mathbb{Z}[ b ]\, , \,\mathbb{Z}[c] .## E.g. if ##p(a):=(a-b)^3+(b-c)^3+(c-a)^3\in \mathbb{Z}[a]## then we have (I change from ##a## to ##x## to make it clearer) ##p(x)=-3x^2b+3xb^2-b^3+(b-c)^3+3x^2c-3xc^2## which we want to divide by ##x-b## and ##c-x.##
I like your version better. At least we have to do it only once for symmetry reasons.
(Edit: Corrected the factor to ##x-b,x-c##.)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
