Use suitable contours in the complex plane and the residue theorem to show that
In summary, the conversation discusses the use of contours in the complex plane and the residue theorem to show that the integral from -infinity to +infinity of 1/(1+(x^4)) dx is equal to pi/(sqrt(2)). The computation of the integral using the residue theorem is shown, with the result being equal to 2πi [(-1/4) e^(πi/4) + (-1/4) e^(3πi/4)] which simplifies to π/√2. The conversation also discusses the use of Euler's Formula and the beauty of complex contour integration.
blueyellow
integral from -infinity to +infinity of [1/(1+(x^4))] dx=pi/(sqrt(2))
Fix R > 1, and consider the counterclockwise-oriented contour C consisting of the upper half circle of radius R centered at the origin (call it γ) and the real axis for x in [-R, R].
So, ∫c dz/(1 + z^4) = ∫γ dz/(1 + z^4) + ∫(x = -R to R) dx/(1 + x^4).
(i) Compute ∫c dz/(1 + z^4) by the Residue Theorem.
The integrand has two singularities in the upper half plane (where C is located):
1 + z^4 = 0 ==> z^4 = -1 = e^(πi) ==> z = e^(πi/4), e^(3πi/4); both are simple poles.
Computing their residues:
At z = e^(πi/4), we have
lim(z→e^(πi/4)) (z - e^(πi/4))/(1 + z^4)
= lim(z→e^(πi/4)) 1/(4z^3)
= lim(z→e^(πi/4)) z/(4z^4)
= e^(πi/4)/(4 * -1)
= (-1/4) e^(πi/4).
Similarly, the residue at z = e^(3πi/4) equals (-1/4) e^(3πi/4).
Therefore, ∫c dz/(1 + z^4) = 2πi [(-1/4) e^(πi/4) + (-1/4) e^(3πi/4)] = π/√2.
but why 2πi [(-1/4) e^(πi/4) + (-1/4) e^(3πi/4)] = π/√2?
Well, try to write [itex]e^{\pi i/4}[/itex] in it's usual form:
[tex]e^{\pi i 4}=\cos(\pi /4)+i\sin(\pi /4)[/tex]
work that out abd substitute that in. Do the same with [itex]e^{2\pi i/4}[/itex]. You'll see that it equals [itex]\pi/\sqrt{2}[/itex].
Expand your result using Euler's Formula and be dazzled. ;) Complex contour integration is a truly beautiful application of complex analysis, as is seen in the result of this integral.
Related to Use suitable contours in the complex plane and the residue theorem to show that
1. What are suitable contours in the complex plane?
Suitable contours in the complex plane are paths that can be used to integrate a complex-valued function. They are typically chosen to simplify the integration process and may include straight lines, semicircles, or other curves.
2. What is the residue theorem?
The residue theorem is a powerful tool in complex analysis that allows us to evaluate certain complex integrals by considering only the residues (singularities) of a function inside a contour. It states that the integral of a function along a closed contour is equal to the sum of the residues of that function inside the contour.
3. How do we show that a function has a residue at a particular point?
To show that a function has a residue at a particular point, we can use the Laurent series expansion of the function around that point. The coefficient of the term with the highest negative power in the series is the residue of the function at that point.
4. Can the residue theorem be used for any contour?
No, the residue theorem can only be used for closed contours. This means that the starting and ending points of the contour must be the same.
5. How can we use the residue theorem to evaluate complex integrals?
To use the residue theorem to evaluate a complex integral, we must first identify the singularities of the function inside the contour. Then, we can calculate the residues at each singularity and use the residue theorem to evaluate the integral. This allows us to avoid the complex calculations involved in directly evaluating the integral.
