Use the formal definition to prove that the following sequence diverges
In summary, the sequence $\displaystyle s_n=\left(\frac1n-1\right)^n$ oscillates between $e^{-1}$ and $-e^{-1}$ for large $n$, and therefore diverges. The proof is done by assuming that the sequence converges to a finite value $L$, and then getting a contradiction by considering subsequence equations and taking limits. Thus, the assumption is false and the sequence must diverge.
alexmahone
304
My attempt:
For large $n$, the sequence oscillates between $e^{-1}$ and $-e^{-1}$ and therefore diverges. Now for the proof.
Assume, for the sake of argument, that the sequence converges to $L$.
$\exists N\in\mathbb{N}$ such that $|s_n-L|<0.1$ whenever $n\ge N$
$\displaystyle\left|\left(\frac1n-1\right)^n-L\right|<0.1$ whenever $n\ge N$
$\displaystyle\implies\left|\left(\frac1{n+1}-1\right)^{n+1}-L\right|<0.1$ whenever $n\ge N$
We can rewrite these 2 equations as
$\displaystyle\left|(-1)^n\left(1-\frac1n\right)^n-L\right|<0.1$ whenever $n\ge N$ --------------- (1)
$\displaystyle\left|(-1)^{n+1}\left(1-\frac1{n+1}\right)^{n+1}-L\right|<0.1$ whenever $n\ge N$
$\displaystyle\implies\left|(-1)^n\left(1-\frac1{n+1}\right)^{n+1}+L\right|<0.1$ whenever $n\ge N$ --------------- (2)
How do I get a contradiction from equations (1) and (2)?
If it is known that $(1-1/n)^n\to1/e$, then you can reason as follows. Suppose $|(1-1/n)^n-1/e|\le0.1$ for all $n\ge N$ (we can achieve this increasing $N$ if necessary). Then (1) with an even $n$ implies that $|L-1/e|<0.2$ and therefore $L>1/e-0.2>0$ and (2) implies that $|(-L)-1/e|<0.2$ and therefore $L<-1/e+0.2<0$, which is a contradiction.
To get a contradiction, we can use the property of limits that if a sequence converges to a certain value, then any subsequence of that sequence must also converge to the same value.
Let's consider the subsequence $\displaystyle s_{2n}=\left(\frac{1}{2n}-1\right)^{2n}$, which is just the even terms of the original sequence. From equation (1), we know that $\displaystyle \left|(-1)^{2n}\left(1-\frac{1}{2n}\right)^{2n}-L\right|<0.1$ whenever $2n\ge N$. This can be simplified to $\displaystyle \left(\frac{1}{2n}\right)^{2n}-L<0.1$.
Now, let's consider the subsequence $\displaystyle s_{2n+1}=\left(\frac{1}{2n+1}-1\right)^{2n+1}$, which is the odd terms of the original sequence. From equation (2), we know that $\displaystyle \left|(-1)^{2n+1}\left(1-\frac{1}{2n+1}\right)^{2n+1}+L\right|<0.1$ whenever $2n+1\ge N$. This can be simplified to $\displaystyle \left(\frac{1}{2n+1}\right)^{2n+1}+L<0.1$.
Now, if we take the limit as $n$ approaches infinity for both of these subsequence equations, we get
$\displaystyle \lim_{n\to\infty}\left(\frac{1}{2n}\right)^{2n}-L=0$
and
$\displaystyle \lim_{n\to\infty}\left(\frac{1}{2n+1}\right)^{2n+1}+L=0$.
But this is a contradiction, as the first limit converges to $0$, while the second limit converges to $2L$. Therefore, our assumption that the original sequence converges to a finite value $L$ must be false, and the sequence must diverge.
FAQ: Use the formal definition to prove that the following sequence diverges
How do you define divergence in a sequence?
Divergence in a sequence means that the terms in the sequence are getting farther and farther apart as the sequence continues. This can also be thought of as the sequence not approaching a specific limit.
What is the formal definition of divergence in a sequence?
The formal definition of divergence in a sequence is that for every real number M, there exists a positive integer N such that if n is greater than or equal to N, then the absolute value of the nth term in the sequence is greater than M.
How can you prove that a sequence diverges using the formal definition?
To prove that a sequence diverges using the formal definition, you must show that for any given real number M, you can find a positive integer N such that if n is greater than or equal to N, then the absolute value of the nth term in the sequence is greater than M.
Can a sequence diverge to infinity?
Yes, a sequence can diverge to infinity. This means that the terms in the sequence are getting larger and larger without bound, and there is no specific limit that the sequence is approaching.
Is it possible for a sequence to both converge and diverge?
No, a sequence cannot both converge and diverge. A sequence can either converge to a specific limit or diverge, but it cannot do both simultaneously.
