MHB Using a while loop to print the counting numbers up to a set value
The discussion focuses on correcting a while loop in C++ that is intended to print numbers from 1 to a given positive integer, userNum. The initial code incorrectly counts down from userNum instead of counting up. To fix this, the loop should use the variable i as an index, starting from 1 and incrementing until it exceeds userNum. The correct implementation involves initializing i to 1, using a while loop that checks if i is less than or equal to userNum, and printing i followed by a space. This adjustment ensures the output matches the expected format, displaying numbers in ascending order.
needOfHelpCMath
Write a while loop that prints 1 to userNum, using the variable i. Follow each number (even the last one) by a space. Assume userNum is positive. Ex: userNum = 4 prints:
1 2 3 4
Code:
#include <iostream>
using namespace std;
int main() {
   int userNum = 0;
   int i = 0;
   userNum = 4;    // Assume positive
while ( userNum > i) {
cout << userNum << " ";
userNum = userNum - 1;
   cout << endl;
   return 0;
Run
✖ Testing with userNum = 4
Expected output: 1 2 3 4
Your output: 4 3 2 1
Technology news on Phys.org
Re: What i am doing wrong?
You need to use [m]i[/m] to "index" your while loop, which should run as it is less than or equal to [m]userNum[/m]. Since [m]i[/m] is initialized to zero, you will want to increment it before the comparison, using [m]++i[/m], and then you will not need to increment it within the loop, you will only need to print its value along with the trailing space.
"Awesome To The Max"
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
13K
11K
30K
