Using air core solenoids in a lab exercise
In summary, the conversation discusses the use of a box of air core solenoids with 700 turns and a current capacity of 7 to 10 amps for a lab exercise. The speaker is looking for suggestions for a more quantitative lab, rather than just a demonstration. They mention the possibility of using compasses to map out the external B-field lines and suggest using an app like phyphox to measure the field. The conversation also mentions @kuruman's insight on modeling a magnet falling through a solenoid and the use of qualitative labs for students to predict the shape of the induced emf. The conversation ends with a reminder to subtract the Earth's magnetic field in data processing.
nmsurobert
288
36
I found a box of air core solenoids and was hoping someone could me think of a useful lab to use them for. They are about 700 turns each. They carry 7 to 10 amps. However I think I think I would only be able to provide 3 amps because of the power supplies I have. I would like to use them to do some actually calculations instead of just demo type things.
Any suggestions are welcome. Thank you!
Science news on Phys.org
Do you have signal generators and oscilloscopes? Do you know the approximate inductance values of the solenoids? Do you have any ferrous rods that would fit inside of the air core solenoids?
Likes hutchphd
What grade level?
I have non of those things. I might be able to find some iron rods though.
hutchphd said:
What grade level?
Most 11th and 12th grade. AP Physics 2.
Do you have a way to measure the magnetic field strength at various points?
Likes berkeman
Oh, good idea. The students could use a compass to map out the external B-field lines and sketch them...
I have a bunch of compasses. I guess I'll end up using them. I like qualitative labs, but these students are very bright and I like challenging them a little bit. However, I'm always short on supplies.
vela said:
You could check out @kuruman's insight. Maybe it'll give you some ideas.
https://www.physicsforums.com/insights/how-to-model-a-magnet-falling-through-a-solenoid/
Qualitative labs can be good too. Have students predict the general shape of the emf induced when they drop a magnet through the solenoid. What happens if they drop the magnet in the other side? Does the curve flip over? Does it stay the same? Explain how they figured it out. That sort of thing.
Thank you for that link! I'll read through it and see if I can take anything from it.
I was thinking more along the lines of something like the Pasco Magnetic Field Sensor since the OP wanted a quantitative lab exercise.
I suppose the students could use an app like phyphox on their smartphones to measure the field and map it.
I've never heard of phyphox. It looks really interesting though. Thank you for that.
Likes BillTre
@nmsurobert -- Whatever method you use to have the students map out the DC magnetic field of the coil, be sure to remind them that the Earth's magnetic field is being vectorially summed with the coil's field in their measurements. So their measurements need to subtract out the Earth's magnetic field vector as part of their data processing.
FAQ: Using air core solenoids in a lab exercise
What is an air core solenoid?
An air core solenoid is a type of electromagnet that consists of a coil of wire wound around a non-magnetic material, usually air. Unlike iron core solenoids, air core solenoids do not use a ferromagnetic core to enhance the magnetic field.
Why would you use an air core solenoid in a lab exercise?
Air core solenoids are often used in lab exercises to study the fundamentals of electromagnetism without the complicating effects of a ferromagnetic core. They allow for a more straightforward analysis of the relationship between current, coil turns, and magnetic field strength.
How do you calculate the magnetic field inside an air core solenoid?
The magnetic field inside an air core solenoid can be calculated using the formula B = μ₀ * (N/L) * I, where B is the magnetic field, μ₀ is the permeability of free space, N is the number of turns, L is the length of the solenoid, and I is the current passing through the wire.
What materials are needed to build an air core solenoid for a lab experiment?
To build an air core solenoid, you will need insulated copper wire, a cylindrical non-magnetic form (such as a plastic or cardboard tube), a power supply to provide current, and measuring instruments like an ammeter and a gaussmeter or a Hall effect sensor to measure the magnetic field.
What are some common applications of air core solenoids in scientific research?
Air core solenoids are used in various scientific research applications, including magnetic field generation for experimental physics, inductance measurement, and as components in radio frequency (RF) circuits. They are also used in educational settings to demonstrate basic principles of electromagnetism.
