Serik
- 8
Use the Biot-Savart equation derived in class for a long, straight wire to show that
B (at the center of a square with sides L and current I) = [tex]\frac{\mu I}{\pi}[/tex] [tex]\frac{2\sqrt{2}}{L}[/tex]
We derived the following in class for a long, straight wire and it was indicated that I should also use this to solve the problem.
|dB| = [tex]\frac{\mu I}{4\pi}[/tex] [tex]\frac{1}{r}[/tex] sin[tex]\theta[/tex]d[tex]\theta[/tex]
If the center of the square = 0 on the x-axis, then the distance along each triangle base = L/2. The center of the square is a distance of L/2 from each side. So r = [tex]\frac{L}{\sqrt{2}}[/tex].
I spent a long time trying to figure this out, and the only way I got the correct answer was by using the same limits of integration as the straight wire example (0 to pi). Doing so makes the integral = 2, which, when put together with r = [tex]\frac{L}{\sqrt{2}}[/tex], yields the final answer when multiplied by 4 (taking into account all contributions to the center of the square).
|B| = 4([tex]\frac{\mu I}{4 \pi}[/tex] [tex]\frac{2 \sqrt{2}}{L}[/tex])
However, setting the limits of integration as 0 and pi doesn't make sense because the wire is not infinitely long, but I cannot figure out how else to show the final answer. So if my algebra is correct, I've got the answer, but it just doesn't seem right.
