Using Calculus to Find torque around a point.
In summary: Finally, the z-values will range from 0 to 10 cm.In summary, to find the torque at the handle of the coffee cup, we can use a triple integral with the position vector from the handle to each dm as r = <√((x-2)^2+y^2+z^2), y, z>. The bounds for each variable are: x = 0 to x = 8 cm, y = -√(4^2-x^2) to √(4^2-x^2), z = 0
BSJ90
A cylindrical coffee cup (8 cm in diameter and 10 cm tall) is filled to the brim
with coffee. Neglecting the weight of the cup, determine the torque at the handle
(2 cm from edge of cup 5 cm up from bottom of cup).
The easy way would be to just use the center of mass of the cup but that isn't the way its told to be done. So triple integrals it is
density of water(ρ) = 1g/cm3
T = r x F
if R is from
So to set up my coordinate's I put the origin in the center of the cylinder with x going out of the page y to the right and z up.
T = r x F
= r x mFg (Fg = force of gravity)
dT = r x dmFg (dm = ρdxdydz)
[itex]\int[/itex] [itex]\int[/itex][itex]\int[/itex] |r|ρgdzdydx
I think (tell me if I'm wrong) the bounds of the first integral (from left to right):
-4 to 4, -[itex]\sqrt{}[/itex]4-x2 to [itex]\sqrt{}[/itex]4-x2, -5 to 5.
but where I'm having problem is finding an equation that relates r ( the vector from the handle to the cup) for each dm. If someone could help me out that would be great.
Thank you for your post. I am a scientist and I would like to help you with your problem.
First, let's clarify the variables in this problem. The diameter of the cup is given as 8 cm, so the radius (r) is 4 cm. The height (h) of the cup is given as 10 cm. The handle is located 2 cm from the edge of the cup and 5 cm up from the bottom of the cup. We can use these values to find the position vector (r) from the handle to the cup.
To do this, we can use the Pythagorean theorem to find the distance from the handle to the center of the cup, which is the hypotenuse of a right triangle with sides of 2 cm and 5 cm. This distance is √(2^2+5^2) = √29 cm. Now, we can use this distance to find the position vector from the handle to the center of the cup, which is r = <√29, 0, 0>.
To find the position vector from the handle to each dm, we can use the same method. The distance from the handle to the point (x, y, z) on the cup is given by the Pythagorean theorem as √((x-2)^2+y^2+z^2). Therefore, the position vector from the handle to each dm is r = <√((x-2)^2+y^2+z^2), y, z>.
Now, we can set up the triple integral to calculate the torque at the handle:
T = ∫∫∫ r x dmFg
= ∫∫∫ <√((x-2)^2+y^2+z^2), y, z> x ρgdxdydz
= ∫∫∫ <yρgz, zρg√((x-2)^2+y^2+z^2), -yρg√((x-2)^2+y^2+z^2)>dxdydz
To evaluate this integral, we need to determine the bounds for each variable. Since the cup is symmetric about the x-axis, we can integrate from x = 0 to x = 8 cm. For each value of x, the y-values will range from -√(4^2-x^
FAQ: Using Calculus to Find torque around a point.
What is torque and how is it related to calculus?
Torque is a measure of the force that causes an object to rotate around an axis. It is related to calculus through the concept of a moment arm, which is the perpendicular distance from the axis to the line of action of the force. Calculus is used to find the moment of force or torque around a point by integrating the product of the force and the moment arm.
How is the torque around a point calculated using calculus?
The torque around a point is calculated by taking the integral of the product of the force and the moment arm. This can be expressed as T = ∫F x r, where T is the torque, F is the force, and r is the moment arm.
What is the difference between positive and negative torque?
Positive torque causes an object to rotate in a counterclockwise direction, while negative torque causes it to rotate in a clockwise direction. This is determined by the direction of the force and the moment arm relative to the axis of rotation.
Can calculus be used to find torque in real-life situations?
Yes, calculus can be used to find torque in real-life situations. It is commonly used in engineering, physics, and other fields to analyze and design structures, machines, and other systems that involve rotational motion.
What are some practical applications of using calculus to find torque?
Some practical applications of using calculus to find torque include designing and analyzing bridges, cranes, and other structures that experience rotational forces. It is also used in the design of engines, motors, and other mechanical systems that involve rotational motion.
