Using differentiation to prove
In summary, the conversation discusses using differentiation to prove that as the radius of the base of a cone increases, the height of the cone decreases. The height expression is derived from calculations involving maximizing the volume of ice-cream in a cone. The goal is to manipulate the volume expression to only include h and r, find the derivative, and show that it is negative to prove the desired result.
casey123
'Use differentiation to prove that as the radius of the base of a cone increases, the height of the cone decreases.'
The height has been previously calculated as:
h = (507 - 2pi r^3) / pi r^2
I have worked out that:
h' = (-1014 - 2pi r^3) / pi r^3
I'm just not sure how to do the proving section though. I can do it without differentiating by replacing values for r in the h equation and also by graphing the h equation, but that doesn't answer the question as differentiation is not used. Any help would be greatly appreciated!
Since the cone has constant volume, you can write it out as
[tex]V=\frac{\pi r^2h}{3}[/tex]. Now, you can write out r and h in terms of the angle of the cone (that the curve makes with the base), differentiate the expression for the volume and show that its a monotonic function and use the relation b/w r and h to prove your result.
Well, that's NOT true is it? Perhaps you forgot to add "a cone with constant volume".
Where did you get that formula? Where is the "507" from? That equation is the same as [itex]\pi r^2 h+ 2\pi r^3= 507[/itex]. The first term of that is 3 times the volume of a cone (or the volume of a cylinder) but I don't recognize the second term (except, perhaps, as (3/4) the volume of a sphere.)
Saying that "as the radius of the base of a cone (with constant volume?) increases, the height of the cone decreases" means that the derivative of the height, with respect to the radius, must be negative.
Yes, it is assuming the volume of the cone is constant. (Thanks for pointing that out!) The question is based around an application concerning ice-cream cones. The first part was to do with maximising the volume of ice-cream that could fit into a cone. The height expression was derived from those calculations.
I think i may have been a bit off track though, after reading your replies. Am I correct in saying that this question (of proving height decreases as radius increases) should concern only the volume of the cone, not the volume i have used (which includes the half-sphere of ice-cream on top)?
Do I then need to manipulate the volume expression so that it is in terms of h and r only, then find the derivative? If this derivative expression is negative is that proof that h decreases as r increases?
Sorry if I've confused anyone, and thanks again helping me. I really need it!
FAQ: Using differentiation to prove
What is differentiation and how is it used in proofs?
Differentiation is a mathematical method used to find the rate of change of a function. In proofs, differentiation is used to show that a function is continuous, differentiable, or to find maximum or minimum values of a function.
Can differentiation be used to prove all mathematical statements?
No, differentiation can only be used to prove statements involving continuous functions. It cannot be used to prove statements about discrete or discontinuous functions.
How does the chain rule play a role in using differentiation to prove statements?
The chain rule is a method used to differentiate composite functions. In proofs, the chain rule is used to simplify the differentiation of complex functions, making it easier to prove statements.
Are there any limitations to using differentiation in proofs?
Yes, differentiation cannot be used to prove statements involving multiple variables or functions. It is also limited to proving statements about continuous functions.
Are there any tips for efficiently using differentiation in proofs?
Yes, it is important to carefully choose the appropriate differentiation rules and techniques for the specific function being used in the proof. It is also helpful to simplify the expression before differentiating and to double check all steps in the proof for accuracy.
