I Using Diffraction (i.e., Fresnel Zone Plate) to defocus/diverge light
Using diffraction principles, particularly with zone plates, to create a divergent beam from a collimated laser is a complex challenge. Zone plates are typically designed for focusing light, akin to convex lenses, rather than diverging it like concave lenses. The discussion explores the potential of using nanoscale solutions, such as flat optics or metasurfaces, to achieve this effect. A proposed idea involves designing a Fresnel mirror that could potentially create divergence, but concerns arise about the feasibility of achieving the necessary phase delay. Overall, the search for effective methods to defocus or diverge light using diffraction remains open and requires further exploration.
jgk5141
TL;DR Summary
Is it possible to defocus collimated light using a concept similar to what is found in a zone plate?
I am wondering if it is possible to use principals of diffraction to cause a collimated beam of light (laser) to become divergent. I see that zone plates are most always used for focusing the light from a source, unless they are used in reverse. This is why zone plates are seemingly always compared to convex lenses. However, I have not been able to find anything that uses diffraction for defocusing or diverging the light, which would be comparable to a concave lens. Does anyone know of any examples of what I am looking for?
Note: I am not limiting the scope of my search to geometrical or large scale optics. I am open to looking at nanoscale solutions, such as flat optics, meta surfaces, or transformation optics, as well as any other solutions.
Maybe design a Fresnel mirror which focuses a parallel beam on to a focal point. The light passing between the zone reflectors will then diverge on the same path, as for a concave lens.
I have thought about this more and I don't think I am correct. Such a device would have a focal point both sides of the lens. To produce a diverging beam, we need more phase delay at the centre than the edge, and I am not sure how to achieve that. Not sure it is possible,
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
