Using energy considerations to analyse particle motion
For a particle to cross the origin, it must possess sufficient kinetic energy to overcome the potential energy at that point, specifically at U(0) = A. The equations presented show the relationship between potential energy and kinetic energy at any position x=a, indicating that the total energy must satisfy the condition A + Ae^{-\alpha a^2} ≤ (1/2)(mv^2_a - ka^2). There is confusion regarding whether to use KE - PE or KE + PE in energy considerations, with the consensus that total energy is conserved. The correct interpretation is that if the particle passes through the origin, then KE + PE must exceed A. Understanding these energy relationships is crucial for analyzing particle motion effectively.
I_Try_Math
(a) Sketch a graph of the potential energy function ## U(x) = \frac {kx^2} {2} + Ae^{-\alpha x^2} ## where k, A, and, ##\alpha## are constants. (b) What is the force corresponding to this potential energy? (c) Suppose a particle of mass m moving with this potential energy has a velocity ##v_a## when its position is x=a. Show that the particle does not pass through the origin unless ## A \leq \frac {mv^2_a + ka^2} {2(1 - e^{-\alpha a^2})} ##
For part (c) my understanding is that in this case for the particle to cross the origin it must have at least as much kinetic energy as there is potential energy at ##U(0) = A##. Given the potential energy and kinetic energy at any position x=a is equal to ## U(a) = \frac {ka^2} {2} + Ae^{-\alpha a^2} ## and ## \frac 1 2mv^2_a ## respectively, this implies that:
##A \leq \frac 1 2mv^2_a - \frac {ka^2} {2} - Ae^{-\alpha a^2} ##
##A + Ae^{-\alpha a^2} \leq \frac 1 2mv^2_a - \frac {ka^2} {2} ##
##A(1 + e^{-\alpha a^2}) \leq \frac 1 2(mv^2_a - ka^2) ##
##2A(1 + e^{-\alpha a^2}) \leq mv^2_a - ka^2)##
##A \leq \frac {mv^2_a - ka^2} {2(1 + e^{-\alpha a^2})}##
Can't tell where I'm making a mistake.
Why do you start with KE-PE rather than KE+PE?
I guess I'm just getting confused. So supposing the particle goes through the origin, ##KE + PE \gt A##, correct?
The total energy is conserved: ##KE(a)+PE(a)=KE(0)+PE(0)=KE(0)+A##
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
