Using integration to find the area between two lines
In summary: I'm not sure if that's right either though.In summary, to find the area under the curve (x/3x) and above the curve (x/3x^.5) between x=1 and x=4, we must first simplify the expressions by raising the power and dividing the number in front by the raised exponent. Then, using the product and quotient rules, we can integrate the expressions. After integrating, we can subtract the integral with x=1 from the integral with x=4 to find the area between the two curves.
Luke77
42
Find the area under (x/3x) and above (x/3x^.5) between x=1 and x=4.
-Area of a representative rectangle= ((x/3x)-(x/3x^.5))dx
-To integrate, raise the power of part of an expression and then divide the number in front by the raised exponent.
I'm not the best at simplifying but here it goes:
∫(x/3x- x/3x^.5)dx
=[((x/2)^2) / (3/2x^2) - ((x/2^2) / (3/1.5)x^1.5] between 1 and 4
From there the answers are not reasonable (too low). Any help?
Is that ##\frac x {3x}## or ##(\frac x 3) x##? Ditto for the second one. And in either case you should simplify before integrating.
∫(x/3x- x/3x^.5)dx
And that wouldn't be how you integrate fractions. Do the algebra first.
∫(x/3x- x/3x^.5)dx
Like LCKurtz said, the way you write it is ambiguous. Write it in ##\LaTeX## and then just subtract one integral from the other. Either case, your integrals are wrong. What you did was make the terrible error that ##\int\frac{f(x)}{g(x)}\mbox{d}x=\frac{\int f(x)\mbox{d}x}{\int g(x)\mbox{d}x}## which is obviously wrong.
As the others have said, this does not really make sense. It would be more reasonable to write the first as simply 1/3 and the second as x^.5/3. If you cannot us LaTeX at least use parentheses to make clear what you mean.
Yes, the integral of [itex]x^n[/itex] is [itex]x^{n+1}/(n+1)[/itex] but you cannot just apply that to parts of an integral, in particular to the numerator and denominator of a fraction. Remember the "product rule" and "quotient rule" for differentiation? You did not just differentiate the parts of a product or quotient and cannot do that for integration.
∫(x/3x- x/3x^.5)dx
[tex]\int_1^4 ((1/3)- (1/3)x^{.5})dx= (1/3)\int_1^4 (1- x^{.5})dx][/tex]
[tex]= \left[x- (1/1.5)x^{1.5}\right]_1^4[/tex]
Thank you everyone so much! I forgot all about the product and quotient rule. I'm sorry for all of my mistakes, I just started learning calculus. Thanks again.
You're absolutely right but I think I was saying that I would integrate everything as x=4 and then subtract integrating it as x=1 to get my answer.
FAQ: Using integration to find the area between two lines
What is integration?
Integration is a mathematical concept that involves finding the area under a curve or between two curves. It is the reverse process of differentiation, and it is used to solve various problems in physics, engineering, and other scientific fields.
How is integration used to find the area between two lines?
To find the area between two lines using integration, we first need to find the points of intersection between the two lines. Then, we can use the definite integral formula to calculate the area between the two lines. This involves finding the antiderivative of the function that represents the difference between the two lines and evaluating it at the points of intersection.
What are the limitations of using integration to find the area between two lines?
Integration can only be used to find the area between two lines if the lines are continuous and do not intersect multiple times. Additionally, if the lines are not functions, but rather curves or shapes, we may need to use multiple integrals to find the area.
Can integration be used to find the area between more than two lines?
Yes, integration can be used to find the area between any number of lines. We can divide the region into smaller sections and use integration to find the area of each section, then add them together to get the total area between the lines.
What are some real-life applications of using integration to find the area between two lines?
Integration is commonly used in physics and engineering to find the area under a velocity-time or acceleration-time graph, which represents the distance traveled or change in velocity. It is also used in economics to calculate the area under a demand or supply curve, which represents the consumer or producer surplus.
