Using Kirchhoff's Laws to Find Currents, Source Current and Power Dissipated
In summary: KVL and KCL, and then we'll see what you're doing wrongIn summary, the conversation is about a circuit shown in Figure Q8 and using Kirchoff's Laws to determine the currents i1, i2, i3, and the source current. The goal is to also calculate the power dissipated by the resistors in the circuit and confirm that it is equal to the power supplied by the power sources. The conversation also includes a discussion about the difficulty in understanding Kirchoff's Laws and the attempt to apply them to the circuit.
cschear87
25
In the circuit shown in Figure Q8 below, if Vs = 10V, use Kirchoff’s Laws to determine the currents i1, i2, i3 and the source current is. Calculate the power dissipated by the resistors in this circuit. Confirm that the power dissipated by the resistors is the same as the power supplied by the power sources.
kirchhoff's current law
kirchhoff's voltage law
i1=i2+i3
I've genuinely tried to get the answers to this but I just don't understand it. I want to understand the answer and how the answer was reached. I have another diagram which I want to do on my own from the help given here.
welcome to pf!
hi cschear87! welcome to pf! :wink:
you can get the ratios of i1 i2 and i3 by doing KVL round each of the two loops at the right (separately)
and you can get the ratio of i5 and i1 by doing KVL round the loop at the left
(and of course KCL gives you i5 = i1 + i2 + i3)
show us what you get :smile:
i1=i2+i3
Can you show one of your attempts? How have you tried to apply Kirchoff's laws?
Any chance you could phrase that as though I was say a 5 year old. lol. I'm just starting this class and feel a bit at the deep end.
Before this post I tried
1/i1 + 1/i2 + 1/i3 - 1/20 + 1/40 + 1/80 = 7/80 = 11Ω
Total R. = 140Ω
V/R = 11/140 = .08 (A?) -- .08 x 11 = .86 -- .86 x 140
=.006
I'm really really bad at math so it was my ABSOLUTE best guess and the book from college was written by the university and thus not great. I got through my binary questions and I'm stuck on algebra *cries*
hi cschear87! :smile:
cschear87 said:
… use Kirchoff’s Laws to determine the currents i1, i2, i3 and the source current is.
Total R. = 140Ω
=.006
no, those aren't using Kirchoff’s Laws
Kirchhoff’s Laws are the circuit (or loop) law (KVL), and the node (or junction) law (KCL)
look them up in wikipedia or the PF Library :smile:
(and then start by applying KVL to the right-hand loop, the one with only i2 and i3)
So does i1 + i2 + i3 = 10v?
I think I understand that voltage in = voltage out. So should the currents add up to 10v?
I = current
and the voltage stays the same in a parallel circuit
sorry, cschear87, but this is nonsense :redface:
how can currents equal a voltage? :confused:
and it isn't "voltage in = voltage out"
it's "current in = current out"​
cschear87, you clearly have no grasp of how Kirchhoff's laws work
you need to read your book (or lecture notes) again, carefully, until you understand them
(or wikipedia, or other websites)
That's what I was saying. I don't understand it. And I've read the notes dozens of times. All two pages in the book I'm given about it. I've just started this course and I'm trying to understand but have limited literature for this subject (there isn't a textbook for this class just notes provided by university). This isn't an excuse, I just don't understand this. This 10Q assignment I've gotten through the first 7 parts without help. I just don't understand based on the material provided. That's why I came here. I thought someone could help. It doesn't matter how many times I read that "the total current flowing into any junction equals the total current flowing out of it" I don't understand. It also doesn't matter how many times I read that "in any closed loop in a network, the algebraic sum of the voltage drops (PDs) around the loop is equal to the emf acting in that loop"... makes no sense. Looks like greek to me. Nevermind
ok, i believe you …
but that doesn't help me explain it to you …
if you don't follow it from the books, how am i going to make any difference? :confused:
all i can suggest is that you think of electric current as being like the current (of water) in a river
when the river divides into three channel (as in the diagram), the total water flowing into the juction has to equal the total water flowing out of the same junction​
... then re-read your book on the junction law (node law, KCL), and see if it makes any more sense
sorry, but i have no suggestion for this, other than to point out that voltage is just another name for energy-per-charge, and KVL is basically an energy equation :redface:
You will get it, maybe see a few different explanations. Tinytim's is above, here is another.
KCL:
Keep in mind what current is -- it is moving charges, inside a wire it is moving electrons. At a point where wires connect, each wire is carrying some moving electrons. If the number of electrons coming into that point did not equal the number of electrons leaving, you would have electrons accumulating there. This is not allowed**. So the number of electrons coming in must equal the number of electrons leaving. If you divide that by time you can speak of the rate at which electrons arrive must equal the rate that electrons leave. This becomes KCL: the sum of incoming currents = the sum of outgoing currents.
*** If electrons were allowed to accumulate at a point, charge would build up and generate an electric field that would oppose and eventually stop the currents from flowing. We call those devices capacitors so when we want to model that we would put a capacitor in the circuit. A simple wire cannot perform this function. A capacitor is actually a broken wire with large plates connected at either end. Electrons do not flow across the broken wire but charges accumulate on the plates.KVL:
As mentioned, this is an energy equation. But maybe you can understand it intuitively. If I take an charged particle at some point in the wire, it will have a certain amount of energy. If I then move this charged particle along the wire, its energy will change because it experiences a force (the electric field) that is summarized in a quantity known as a voltage. But if I keep moving this particle around the wire and come back to the point I started at, it should have the same energy as when I started.
KVL means the change in energy as I travel around a closed loop is zero. The energy changes are measured as voltage drops across each circuit element (the wire itself is assumed ideal with no resistance and therefore no energy drop; if it were not ideal it would be modeled as a resistor on an ideal wire).
KCL:
KVL:
OK, I think I understand a bit better now. CURRENTS in = CURRENTS out and voltage drops when contact is made with each circuit element. That seems to make sense. How do I put that information into an equation based on my diagram?
what do you get? :smile:
For KVL, the sum of the voltages = 0. Right?
For KCL current in = current out. So depending on the arrows in the diagram, and how they connect to the nodes, that would, I guess, dictate the equation. If generally i1 = i2 + i3, then iS = i1 + i2 + i3?
(let's leave KCL for the moment, it's a bit more complicated than it looks)
Yes, the sum of the voltage drops has to be zero, because the emf (in that loop) is zero.
ie, the RHS of the KVL equation is zero.
So, in terms of I and R, what is the LHS? :smile:
So is the current Voltage (I)/Resistance (R)?
Voltage is 10V and would resistance be 20, 40 and 80?
(LHS? Not far enough to know abbreviations yet :( )
LHS is left-hand-side, and RHS is right-hand-side (of an equation)! :biggrin:
ok, i'll do this one for you …
KVL for the right hand loop:
the RHS is 0
(because there's no emf in the loop)​
the LHS is 80i3 - 40i2
(because the voltage drop across each resistor is IR, and because if we go round clockwise then i3 is positive and i2 is negative)​
so the whole KVL equation is 80i3 - 40i2 = 0,
ie i2 = 2i3 :smile:
(btw, if we'd gone anti-clockwise round the loop, it'd have been -80i3 + 40i2 = 0, which still gives i2 = 2i3, doesn't it?
so it doesn't matter which way we go round ! :wink:)
any questions about all that?
if not, now you try the middle loop (the one with i1 and i2) :smile:
the RHS is 0
ie i2 = 2i3 :smile:
2i1 - i2?
= 2(20) - 40 = 0
that doesn't make sense :redface:
write it in the standard form, i1R1 + (or -) i2R2 = 0
I think where I'm confused is what exactly is R. There's no R in the diagram which is partially why I'm confused I think. And I thought that I had to use the current law to find the current for the first part of the question. I'm confusing myself :blushing: And you're very good to try and help. This course is all online with my university so I have very little interaction with other students and professors unfortunately which is why I haven't gotten an answer back about this from them. Online tutorial next week though. :smile:
R is the resistance (easy to remember!)
(V is for voltage, C is for capacitance, I is for something German, i think :wink:)
so in this case R is either 20 or 40 :smile:
So, 2(20i1) - 40(i2) = 0?
20i1 - 40i2 = 0 :wink:
(where did your "2" come from? :confused:)
so i1 = 2i2
ok, now try the left-hand loop (the one with V5 i5 and i1) :smile:
so i1 = 2i2
Thought it had to = 0?
So r5 is 10
So 2i5 = i1? - 2(10i5) = 20i1
or
2 (10) = 20
now you're completely losing me :confused:
you thought what had to = 0?
and can we go back a little … where did that "2" come from? (i see you have another one a couple of lines down)
let's sort those two things out before we look at the rest of what you did
I thought the equation had to =0. The 2 (both times) were because I thought the equation had to come to 0
it depends how you write it
for KVL, i usually put V on one side, and the IRs on the other side
but of course you can put them all on the same side (being careful about the signs), and 0 on the other
let's see, you originally wrote 2(20i1) - 40(i2) = 0
but the correct equation was 20(i1) - 40(i2) = 0 (IR + IR = V) …
why did you think there had to be a 2 there? (i need to know to stop you doing it again! :wink:)
lol, Well, I thought that 2 x 20 =40 and therefore 40-40=0. It all comes back to thinking things = 0. So is this to determine the current or the voltage? :confused:
oh now i see!
ok, you're trying to balance the two Rs on their own,
ie you have 20Ω and 40Ω, and you know you have to multiply each one by something to get 0
but that's what the current is for
you multiply each R by its I and nothing else
you must follow the formula! (for KVL)​
try again :smile:
KVL is sometimes to determine the current, and sometimes to determine the voltage
in this case, you know the voltage (it's 0 in that loop), but you don't know either of the two currents …
so this KVL gives you one equation to help you find the two unknown currents :smile:
(obviously, you always need two equations to find two unknowns, so you'll need another equation from somewhere else)
So the right loop ie the 80Ω and 40Ω i3 and i2
=80i3 - 40i2 = 0 OR i2 = 2i3
Middle is the 20 and 40 ie i1 and i2. So
i1 = 2i2 40i2 - 20i1 = 0
The left? Is there not voltage already there on the left as 10 volts is Vs.
So I5 = 2i1
10i5 - 20i1 = 0?
  • #31
yes and yes :smile:
so i1 = 2i2 = 4i3
So I5 = 2i1
10i5 - 20i1 = 0?
no
the arrows for i5 and i1 are both clockwise, so the IR is positive for both
also, you need to put the 10 V on the RHS …
10i5 + 20i1 = 10 :wink:
(or is it -10? i can never remember which way round it is! :redface:)
first, any questions about that?
second, now try KVL for the outside loop (the one with V5 i5 and i3) :smile:
  • #32
tiny-tim said:
yes and yes :smile:
so i1 = 2i2 = 4i3
no
I thought that about the voltage but wasn't sure. So the right and middle loops have no voltage immediately in them so they have to balance out. But because on the left there's 10 volts going directly into that loop, the equation has to = 10? Is that right?
The outside loop is...
10i5 + 80i3 = 10?
  • #33
yup! :smile:
so we have i1 = 2i2 = 4i3
10i5 + 20i1 = 10
10i5 + 80i3 = 10
(and if we do the other two loops, we would get:
10i5 + 40i2 = 10
20i1 = 80i3)
note that the outside loop gives us no new information …
from 10i5 + 20i1 = 10 and i1 = 2i2 = 4i3,
we can get 10i5 + 80i3 = 10 anyway (without KVL) :wink:
the moral is that you only need as many KVL equations as there are independent loops (in this diagram, there are 6 loops altogether, but only three are independent … so in this case you need exactly 3 KVL equations, and any more would be superfluous …
in this case, we chose 2 really easy loops, with V = 0, and only one loop with V ≠ 0, to keep it as simple as possible! o:))​
ok, now that should give you the answer to the first part of the question: what are the currents i1 i2 i3 and i5
any questions? :smile:
  • #34
tiny-tim said:
yup! :smile:
10i5 + 20i1 = 10
10i5 + 80i3 = 10
10i5 + 40i2 = 10
20i1 = 80i3)
So now that I have the equations and have some understanding, what exactly does that tell me about the currents? And how do I confirm this with power dissipated?
  • #35
(btw, there's no need to keep repeating the entire previous post! :wink:)
those equations tell you what the currents are, don't they? :confused:
write out the power equations :smile:
