Using Mathematical Induction to Prove a Summation Formula
The discussion focuses on using mathematical induction to prove the summation formula for \( S_k = 5 \cdot 6 + 5 \cdot 6^2 + \ldots + 5 \cdot 6^k = 6(6^k - 1) \). The next step involves proving \( S_{k+1} \) by adding \( 5 \cdot 6^{k+1} \) to both sides of the equation. The right-hand side is manipulated to show that it can be expressed as \( 6(6^{k+1} - 1) \). Through algebraic manipulation, terms are combined and factored to arrive at the desired form. The proof successfully demonstrates the validity of the summation formula using induction.
ineedhelpnow
$S_k:5\cdot 6 +5\cdot 6^2+5\cdot 6^3+ ...+5\cdot 6^k=6(6^k-1)$$S_k:5\cdot 6 +5\cdot 6^2+5\cdot 6^3+ ...+5\cdot 6^k+ 5\cdot 6^{k+1}=6(6^k-1)+5\cdot 6^{k+1}$
what do i do now? to prove $S_{k+1}$
Mathematics news on Phys.org
The second statement should be labeled as $S_{k+1}$ and you want the right side to be:
$$6\left(6^{k+1}-1\right)$$
Can you get from what you have to there algebraically?
By the way, I am going to move this thread to the Pre-Calculus subforum and retitle it to remove the abbreviation.
i don't know how to get there
here's all I've done so far:
RHS
$6^{k+1}-6+5\cdot 6^{k+1}$
RHS
Okay, combine like terms and then factor...
$[6^{k+1}+5\cdot 6^{k+1}-6$
$[6^{k+1}(1+5)]-6$
$6[6^k(6)-1]$
$6(6^{k+1}-1)$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
