Using Momentum Principle to Find Ratio of Speeds?
  • Thread starter Thread starter Spooky123
    Momentum Velocity
The discussion centers on applying the momentum principle to derive the ratio of speeds between two ions, one being a hydrogen ion and the other having a mass 12 times greater. The initial velocity of both ions is zero, leading to an average velocity expression of Vavg = vf/2. Using the momentum principle, the relationship between force, mass, and velocity is established, resulting in a ratio of speeds calculated as 1/12, which is deemed incorrect. Participants emphasize that the problem should solely utilize momentum and velocity equations without involving acceleration, and there is confusion regarding a numerical answer presented without units, questioning its relevance to the task of deriving a velocity expression.
Spooky123
Two different experiments are performed. In the first experiment, a constant force is applied to a hydrogen ion. In the second experiment, the same constant applied force is applied to an ion that has a mass 12 times the mass of hydrogen. In each experiment, the ion is at rest at location A. Note that this force is much larger than any possible gravitational force on the ions, so you can neglect gravity.
Derive an expression for the final y-velocity of an ion as a function of its mass, the time interval At, and the force on the ion F.
Pf = Pi + FnetT
Vavg = v1 + v2 / 2
Vavg = r/t
Given that the ions are initially at rest my initial velocity is 0. Therefore my Vavg is equal to vf/2
Using the formula Vavg = Change in positon/time, I can solve vf to be equal to 2r/t.
Using the momentum principle, I get an equation of 2r/t = FnetT/12m -> Given that the mass of the ion is 12x Hydrogen.
However, when I solve for FnetT/12m divided by FnetT/m I get a ration of 1/12. Which is incorrect...
This question should only use the momentum principle and velocity equations without having to involve acceleration.
Spooky123 said:
Homework Statement: Two different experiments are performed. In the first experiment, a constant force is applied to a hydrogen ion. In the second experiment, the same constant applied force is applied to an ion that has a mass 12 times the mass of hydrogen. In each experiment, the ion is at rest at location A. Note that this force is much larger than any possible gravitational force on the ions, so you can neglect gravity.
Relevant Equations: Derive an expression for the final y-velocity of an ion as a function of its mass, the time interval At, and the force on the ion F.
Pf = Pi + FnetT
Vavg = v1 + v2 / 2
Vavg = r/t
If you are acting on both ions for the same amount of time, then
##v = v_0 + aT##
Assuming that ##v_0 = 0## m/s for both, then
##v = aT##.
Now, ##F = ma##, so
##v = \dfrac{FT}{m}##
So, for Hydrogen:
Let's call the other ion carbon. So for carbon:
##V = \dfrac{FT}{12m}##
The ratio of these will be
##\dfrac{V}{v} = \dfrac{1}{12}##
as you said above.
-Dan
Spooky123 said:
Pf = Pi + FnetT
You have all the ingredients above to do what you are asked. Remember that pi = 0. You don't need any velocity or acceleration equations.
The correct answer for this question is 0.2889. I guess it might be an error.
How can the correct answer be a number (with no units) when the task is to "Derive an expression for the final y-velocity of an ion as a function of its mass, the time interval At, and the force on the ion F"?
Likes topsquark and nasu
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
