fluidistic
- 262
From a locked thread:
2)I have to use common sense here, pure intuition would leave me clueless. Say you have a very, very, very heavy little ball inside a boat, making water level up. Clearly, this ball makes the boat almost go under water (I don't know the name in English). If you remove it from the boat and throw it in water, a big part of the boat will emerge and the water level will go down. So common sense says water goes down.
3)I don't know what a treadmill is. Google translation and good picture seems to show a gym apparatus. Well, if the effect is to make the wind speed 0 with respect to the wings of the plane, we must imagine a bird that doesn't move his wings under no wind. Can it fly? As far as I know, no. So intuition says no, if I'm understand well the action of a treadmill. I will add one that I found much harder to answer without a basic physics knowledge that you don't find with intuition only. If you throw up a rigid body into the air, does it take more time to goes up or fall down?
My answer with common sense: Say you throw it with a huge speed upward, exceeding the terminal velocity of the object, it will reach its maximum height faster than falling down since when it will fall down it will reach the terminal velocity. Now if you throw it upward with a velocity lesser than the terminal velocity, I don't think common sense can answer the question.
I didn't use any math to answer these questions, so yes my intuition might be all wrong. What says yours?
1)When the car goes forward we tend to go backward and our back is pressed into the sit, so I'd say the balloon does the same, i.e. goes backward. It would be counter intuitive if it went the other way.micromass said:You absolutely need mathematics in physics. It may seem unnecessary at first, but after a while you'll see many counterintuitive things that can only be worked out with mathematics.
For example, consider these questions:
1) A helium balloon flies in a car, the car stops, does the balloon go backwards or forwards?
2) You are with a ship in a lake and you have a heavy rock in your ship. You drop the rock in the water, does the water level go up or down?
3) There an airplane on a threadmill. The threadmill goes as fast as the plane. Can the plane fly?
These three question are impossible (for me) to answer with intuition. You must use mathematical models here and you must calculate things. Physicists don't use math for fun, but because it's necessary!
