Using only the numbers 3, 3, 3 and 3 once and + - * / once find 7?
  • Thread starter Natasha1
  • Tags
    Numbers
In summary, the conversation discusses a puzzle given by a lecturer involving using the numbers 3, 3, 3, and 3 once and the four arithmetic operations to make the number 7. Several attempts have been made, but the closest solutions are 6 and 8. There are 24 possibilities to try, but it is discovered that any combination of operations except for 3/3 will result in a multiple of 3. It is also suggested to use parenthesis to group operations.
Natasha1
493
Hi,
At the end of our lecture today, the lecturer gave us this simple yet impossible puzzle.
My friend and I have tried to find the answer but in vain...
Using only the numbers 3, 3, 3 and 3 once and using only the four arithmetic + - * / once can you make the number 7.
The closest I have got is 6 or 8 but not 7.
3*3 all / 3 and then + 3 = 6
or
3*3 then - 3/3 = 8
How to find 7?? Is this actually possible?
Mathematics news on Phys.org
3 + 3 + 3/3 = 7
think of it in terms of combinatorics with the operators:
3 op1 3 op2 3 op3 3
so there's 4 choices for the first, 3 for the third, 2 for the last one = 24 choices
Phyzguy's solution is almost correct except that he repeated the + operator and the problem says to use each operation once.
3+3-3*3=-3
3+3-3/3=5
3+3*3-3=9
3+3*3/3=6
3+3/3-3=1
3+3/3*3=3.33333
3-3+3*3=9
3-3+3/3=1
3-3*3-3=-9
3-3*3/3=0
3-3/3+3=5
3-3/3*3
Can't do 3 + 3 + 3/3 = 7 as you are using + twice
Are you saying it's therefore impossible?
I can't tell you the answer only how to think about the problem as it was assigned by your prof.
Pity.
Natasha1 said:
Pity.
You can't finish the other 12 choices to complete the proof?
are you sure the prof or you have the correct problem?
a classic is using 5 "3" and all the operators
(3*3 + 3)/3 + 3 = 7
But then you are using + twice too
3 and 7 are prime numbers. Any combination of operations you try (except for 3/3) will be a multiple of 3. If you use 3/3 = 1, then you'd have to add or subtract the 3/3 to something else, since multiplying would result in a multiple of 3 again, and dividing would result in a fraction.
The problem doesn't state if you're allowed to use parenthesis to group operations.
If you're suppose to used + - * / excactly one, that's four operators, so you'd need five 3's.
FAQ: Using only the numbers 3, 3, 3 and 3 once and + - * / once find 7?
How is it possible to find 7 using only the numbers 3, 3, 3, and 3?
It is possible to find 7 by using mathematical operations such as addition, subtraction, multiplication, and division. The challenge is to use each of the numbers 3, 3, 3, and 3 only once and the mathematical operations only once.
Can you provide an example of how to find 7 using the given numbers and operations?
One example could be: (3+3) * (3/3) + 3 = 7
Are there any other ways to find 7 using only the numbers 3, 3, 3, and 3?
Yes, there are multiple ways to find 7 using these numbers and operations. Some examples include: 3 * (3+3) - 3/3 = 7 and 3 * (3-3) + 3/3 = 7.
What mathematical concepts are involved in finding 7 using only these numbers and operations?
The mathematical concepts involved include basic arithmetic operations (addition, subtraction, multiplication, and division), order of operations, and using parentheses to group numbers and operations.
Can this problem be solved using other numbers and operations?
Yes, this problem can be solved using other numbers and operations. As long as the mathematical operations are limited to + - * / and the given numbers are used only once, any target number can be achieved.
