Using Radio Antennae to Dump Stored Energy
In summary, a spacecraft at a large distance from any star needs to dump a tremendous amount of stored electrical energy overboard in a limited timeframe. The usual method of using heat radiators is not feasible due to the limited surface area available. Instead, a radio transmitter could be used to effectively dissipate the energy. This could be achieved by connecting a resistor between the plates of a super-capacitor or by using an electrical arc onto a conducting object outside the craft. A formula could be used to determine the power output of the transmitting antenna based on its size and temperature.
MattRob
211
29
So, let's say a spacecraft at a large distance from any star needs to dump a tremendous amount of stored electrical energy overboard in a limited timeframe.
Normally, spacecraft dump excess/waste energy using heat radiators. In this unusual case, however, the energy is electrical, and heat radiators require a tremendous amount of surface area that's already needed for other uses (that is, a tremendous amount of area would be needed to radiate this amount of energy, limited to roughly 2000*C, and in a reasonable timeframe, and most available surfaces on the craft are already taken with radiators for the powerplant and engines, due to waste heat).
Since it is already stored as electricity, would a radio transmitter work as a more effective means to dump this energy than heat radiators?
Electrical resistance goes down with temperature and eventually superconductivity is achieved, right? So could the antenna array be made superconducting to allow for an exceedingly low resistance?
Is there some kind of formula I could use to plot the amount of power this transmitting antenna is putting out given several parameters (such as it's size, it's temperature, etc)? That would probably be most helpful.
What do you mean by "stored as electricity"? You mean you have some large amount of unbalanced charge in some super-capacitor?
Yes, that would do.
You can just connect a resistor between the plates of the capacitor.
The energy will be dissipated. You can put the resistor outside the spacecraft so the heat is radiated in space.
But I am afraid that you may have some other scenario in mind. :)
I would have to wonder what the benefits of just 'discarding' such energy would be but to answer the question I wouldn't imagine that radio waves would be particular effective per se. Radio waves encompass a large frequency range which is inclusive of microwaves as well. If we are discussing the utilization of microwaves then perhaps this could be effective but in all truthfulness I can say that a simple spark or electric arc onto some conducting object outside the craft would be immediate and super effective. I have seen the discussion on the possibility of electrical arcs in a vacuum space that was engaged by a NASA doctor and it seems as of this would be the ideal method.
Related to Using Radio Antennae to Dump Stored Energy
1. How does using radio antennae help to dump stored energy?
Radio antennae can be used to convert stored electrical energy into electromagnetic waves, which can then be released into the atmosphere. This process is known as "dumping" the energy and helps to prevent potential damage or safety hazards that may arise from the overloading of energy storage systems.
2. What types of stored energy can be dumped using radio antennae?
Radio antennae can be used to dump various forms of stored energy, such as electrical energy from batteries, capacitors, or generators. It can also be used to dissipate thermal energy from heat sinks or other thermal storage systems.
3. What are the benefits of using radio antennae to dump stored energy?
Using radio antennae to dump stored energy offers several benefits. It helps to prevent energy storage systems from becoming overloaded, which can lead to safety hazards or damage. It also allows for more efficient use of energy, as excess energy can be released into the atmosphere instead of going to waste.
4. Is there a limit to how much energy can be dumped using radio antennae?
The amount of energy that can be dumped using radio antennae depends on several factors, including the size and type of the antennae, the frequency and power of the radio waves, and the type and capacity of the energy storage system. Generally, the higher the power and frequency of the radio waves, the more energy can be dumped.
5. Are there any potential drawbacks to using radio antennae to dump stored energy?
While using radio antennae to dump stored energy can be beneficial, it is important to consider potential drawbacks. For example, the release of electromagnetic waves into the atmosphere can potentially interfere with other electronic devices. It is also important to carefully design and calibrate the antennae to ensure safe and efficient dumping of energy.
  • Mechanical Engineering
  • Astronomy and Astrophysics
