Undergrad Using Residues (Complex Analysis) to compute partial fractions
The discussion focuses on computing the partial fraction decomposition of the rational function f(z) = (z+2)/((z+1)²(z²+1)) using residue theory in complex analysis. Participants clarify how to handle double poles, particularly at z = -1, and emphasize the importance of the residue at this point. The correct approach involves using the residue formula for higher-order poles, and there is a debate over the values of constants A1 and A2 derived from the residues. The conversation concludes with a method for deriving the Laurent series around the pole, which aids in finding the residue and confirms the analytical properties of the function.
cbarker1
MHB
TL;DR
How to compute partial fractions decompose when one the factors is a root of multiplicity in the residue method?
Dear Everybody, I am wondering how to compute the partial fraction decomposition of the following rational function: ##f(z)=\frac{z+2}{(z+1)^2(z^2+1)}.##
I understand how to do the simple poles of the function and how it is related to the decomposition's constants, i.e. ##f(z)=\frac{A_1}{z+i}+\frac{A_2}{z-i}+\frac{B_1}{z+1}+\frac{B_2}{(z+1)^2}##. Thus, I know that ##A_1=-\frac{i+2}{4}## and ##A_2=-\frac{-i+2}{4}.## But how do I computes double pole in terms of the residue, if possible? How I can write out ##B_1, B_2.##
Setting z = 0 gives <br /> 2 = i(A_2 - A_1) + B_1 + B_2. Setting z = 1 gives <br /> \frac 38 = \frac{A_1 + A_2 + i(A_2-A_1)}{2} + \frac {B_1}2 + \frac{B_2}4. Once A_1 and A_2 are known, this system can be solved for B_1 and B_2.
ok. thanks for your input. But, I think you may not answer my question because I am wondering how to do the partial fraction decomposition with respect to residue theory in complex analysis the multiple roots case?
For ##B_2##, define
\begin{align*}
g(z) = (z+1) f(z)
\end{align*}
Then
\begin{align*}
\text{Res} [g(z_0=-1)] = \text{Res} [\frac{B_2}{z+1}] = B_2
\end{align*}
You understand why:
\begin{align*}
\text{Res} [f(z_0=-1)] = \text{Res} [\frac{B_1}{z+1}] = B_1 ?
\end{align*}
where you would use the general formula for the residue of an ##nth-##order pole
\begin{align*}
\text{Res} [f(z_0)] = \frac{1}{(n-1)!} \lim_{z \rightarrow z_0} \left( \dfrac{d^{n-1}}{dz^{n-1}} [(z-z_0)^n f(z)] \right) .
\end{align*}
Are you sure your answers to ##A_1## and ##A_2## are right? So you are equating
\begin{align*}
\text{Res} [f(z_0=-i)] = \text{Res} [\frac{A_1}{z+i}] = A_1
\end{align*}
and then using
\begin{align*}
\text{Res} [f(z_0=-i)] = \lim_{z \rightarrow -i} [(z+i) f(z)]
\end{align*}
but I get ##A_1 = - \dfrac{-i+2}{4}##.
I was led astray by your statement <br /> f(z) = \frac{A_1}{z + i} + \frac{A_2}{z-i} + \frac{B_1}{z+1} + \frac{B_2}{(z + 1)^2} and therefore assumed you meant a partial fraction decomposition. But you meant to calculate the residue of f at -1 instead. A function has only one residue at a root of its denominator, regardless of the multiplicity of that root.
But to compute the Laurent series of f about -1 is fairly straightforward, if you do not know the formula quoted by @julian: <br /> \begin{split}<br /> f(z) &amp;= \frac{z + 2}{(z+1)^2(z^2+1)} \\<br /> &amp;= \frac{(z + 1) + 1}{(z+1)^2(z^2+1)} \\<br /> &amp;=\frac{1}{z^2 + 1}\left(\frac1{(z+1)} + \frac{1}{(z+1)^2}\right).<br /> \end{split} The common factor g(z) = (z^2 + 1)^{-1} is analytic at z = -1, so it has a Taylor series which converges in some open neighbourhood of it. So \begin{split}<br /> f(z) &amp;= \sum_{n=0}^\infty \frac{g^{(n)}(-1)(z + 1)^n}{n!}\left(\frac1{(z+1)} + \frac{1}{(z+1)^2}\right) \\<br /> &amp;= \frac{g(-1)}{(z + 1)^2} + \sum_{n=-1}^\infty\left(\frac{g^{(n+1)}(-1)}{(n+1)!} + <br /> \frac{g^{(n+2)}(-1)}{(n+2)!}\right)(z + 1)^n <br /> \end{split} and the residue is g(-1) + g&#039;(-1).
1. Start with the global analytic continuation of the Riemann zeta function found here. 2. Form the Haadamard product. 3. Use the product to series formula from functions.wolfram.com or Theory and Applications of Infinite Series by Konard Knopp, Dover books 1943. 4. Apply series revision to solve for the zeroes from Stewart Calculus, 4th edition. Benjamin Orin and Leonard Mlodinow solved this.
  • · Replies 22 ·
