Using Seismic Waves detected at 4 Seismometers to determine the Epicenter
In summary: The focus is at the intersection of the two longest sides.In summary, you tried to find the focus by locating the difference in arrival times, the angle between the stations, and the distances between the stations. You uploaded a PDF or JPEG of your sketch, and said that you would post math equations if requested.
Ira_anabelle
Earthquake:
You know the geographical position of four different seismometers, the speed of the s-wave and p-wave, the level of the focus under the earths surface and the times of arrival of both of the waves at each station. Determine a way to find the exact location of the epicenter.
Note that the primary (p)-wave arrives before the secondary(s)-wave.
N/A
My first attempt was to work with the the difference in arrival times, but that didnt account for the focus to be under the epicenter. So I tried again in combination with the angle between the stations but have not arrived at a clear solution.
Welcome to PF.
Can you show your work so far? That will help us a lot in being able to help you. also, if you have a sketch of the arrangement, that would also help. Click "Attach files" below the Edit window to upload a PDF or JPEG copy of your sketch.
Also, to post math equations, it's best to use LaTeX. See the "LaTeX Guide" link below the Edit window to learn more. :smile:
There does seem to be a surfeit of information. Knowing the difference in p/s arrival times and their speeds at three stations should be enough to locate the focus. The fourth station and given depth seem unnecessary. Hard to know whether you are expected only to use whatever sufficient set of data you choose, or you are supposed to use some likelihood maximisation.
But I don't understand how you can have computed the epicentre except by locating the focus. Please post the details of your attempt.
Mind, I am assuming that the stations are not too far apart, or you will have to worry about the core.
To be honest I didnt find my notes with the angle calculation of the center of the earth. Just these ones. I tried to get a formula for the epicentral distance first, to combine three of them an then find the Epicenter. I don't think it‘s right since I am not using the sphere/geographical coordinates.
There is btw the information given that the speeds are set to be constant and the distance are small. I forgot to write it into the question.
  • Homework.pdf
I see no way to do that. The waves come from the focus, not the epicentre. You can calculate the distance from the focus to each station. That gives you a pyramid (inverted) on a quadrilateral base.
