Using Substitution to Solve Cubic Equations
In summary, the conversation discusses how to solve the cubic equation x^3 + 3(x^2) +2 =O by using the substitution X=1/(u^0.5). The result is 4u^3+12u^2+9u-1 =0, which can be simplified by isolating $\sqrt{u}$ and then squaring both sides. The 12 in the equation comes from squaring the binomial $3+2u$.
Harry2
Hi,
I don't understand how to get to the answer of the question. The cubic equation x^3 + 3(x^2) +2 =O.by using substitution X=1/(u^0.5) get 4u^3+12u^2+9u-1 =0.
I can't see where the 12 comes in
It's question 10i
Mathematics news on Phys.org
We are given the cubic polynomial:
\(\displaystyle x^3+3x^2+2=0\)
And we are instructed to use the substitution:
\(\displaystyle x=\frac{1}{\sqrt{u}}\)
And so the cubic becomes:
\(\displaystyle \left(\frac{1}{\sqrt{u}}\right)^3+3\left(\frac{1}{\sqrt{u}}\right)^2+2=0\)
If we multiply through by $u\sqrt{u}$, we get:
\(\displaystyle 1+3\sqrt{u}+2u\sqrt{u}=0\)
Next, let's arrange as:
\(\displaystyle \sqrt{u}=-\frac{1}{3+2u}\)
Square both sides:
\(\displaystyle u=\frac{1}{9+12u+4u^2}\)
Do you see how the 12 came from the squaring of the binomial $3+2u$?
Multiply through by $9+12u+4u^2$ and then subtract through by 1, to obtain:
\(\displaystyle 9u+12u^2+4u^3-1=0\)
Arrange in standard form:
\(\displaystyle 4u^3+12u^2+9u-1=0\)
Thank you! I was constantly getting the wrong answer.
- - - Updated - - -
Why though do you factorise the u^.5. Can't you just square it?
- - - Updated - - -
Isolating $\sqrt{u}$ makes the squaring process simpler. :)
FAQ: Using Substitution to Solve Cubic Equations
What are the roots of a polynomial equation?
The roots of a polynomial equation are the values of the variable that make the equation equal to zero.
How can I find the roots of a polynomial equation?
There are several methods for finding the roots of a polynomial equation, including factoring, using the quadratic formula, and using synthetic division. The method used depends on the degree and complexity of the polynomial.
What is the relationship between the roots of a polynomial equation and its graph?
The roots of a polynomial equation are the x-intercepts of its graph. This means that when a polynomial equation is graphed, the points where the graph crosses the x-axis are the roots.
Can a polynomial equation have more than one real root?
Yes, a polynomial equation can have multiple real roots. The number of real roots a polynomial has is equal to its degree, but some of these roots may be repeated.
What is the fundamental theorem of algebra?
The fundamental theorem of algebra states that every polynomial equation with complex coefficients has at least one complex root. This means that for a polynomial equation with degree n, there will be n complex roots, some of which may be repeated.
