Using The Completeness Axiom To Find Supremum and Saximum.
In summary, the book claims that the set T (defined by my previous reply) does not have a supremum when considered as a subset of the rationals, but this is contradicted by the fact that T has a supremum when considered as a subset of the reals. Additionally, the book claims that the set does not have a supremum when considered as a subset of the reals, but this is contradicted by the fact that T has a supremum when considered as a subset of the rationals.
mliuzzolino
58
For each subset of ℝ, give its supremum and its maximum. Justify the answer.
{r [itex]\in \mathbb{Q} [/itex] : r2 ≤ 5}
Maximum: If an upper bound m for S is a member of S, then m is called the maximum.
Supremum: Let S be a nonempty set of ℝ. If S is bounded above, then the least upper bound of S is called its supremum.
Supremum: none, Maximum: none.
We can see that [any positive real number x such that x2 ≤ 5 is an upper bound. The smallest of these upper bounds is [itex]\sqrt{5}[/itex], but since [itex]\sqrt{5} \notin \mathbb{Q}[/itex], then the set has no maximum. Additionally, since [itex]\sqrt{5} \notin \mathbb{Q}[/itex] the set does not have a supremum.
I think this is correct, but I'm not exactly sure. Is there no supremum because even though the least upper bound exists, [itex]\sqrt{5}[/itex], this least upper bound is not in the set of rationals and therefore the set has no supremum?
The supremum does not have to be inside of your set. ##\sqrt{5}## is indeed the supremum.
The book gives some other example where the set T = {q [itex] \in \mathbb{Q}[/itex]: 0 ≤ q ≤ [itex]\sqrt{2}[/itex]}.
The book then claims that it does not have a supremum when considered as a subset of [itex]\mathbb{Q}[/itex]. The problem is that sup T = [itex]\sqrt{2}[/itex], and [itex]\sqrt{2}[/itex] is one of the "holes" in [itex]\mathbb{Q}[/itex] - that is, [itex]\sqrt{2}[/itex] does not exist in [itex]\mathbb{Q}[/itex] and therefore cannot be a Supremum.
Wouldn't the same exact argument apply for [itex]\sqrt{5}[/itex]?
Lets call your set S.
S is nonempty ( clearly, take r = 1 ), S is also bounded above ( Plenty of elements, 5 is an upper bound if you so please ), and you're viewing S as a subset of ##\mathbb{R}## not ##\mathbb{Q}##.
So S has to have a supremum by the axiom.
What exactly does the book mean when it says that when considered as a subset of the rationals, the set does not have a supremum?
The book then goes on to say that "Every nonempty subset of S of the reals that is bounded above has a least upper bound. That is, sup S exists and is a real number."
This seems to completely contradict what it is saying that the set T (as defined by my previous reply) does not have a supremum when considered as a subset of the rationals. It seems that my problem is contingent upon that last part "subset of the rationals," but isn't a subset of the rationals also a subset of the reals, and by the definition, every nonempty subset S of the reals has a supremum?
When you regard S as a subset of the reals, you have access to the completeness axioms for your arguments. Since ##\sqrt{5} \in \mathbb{R}##, and ##\sqrt{5} ≥ r## we know ##sup(S) = \sqrt{5}## in this case.
The problem when you view S as a subset of the rationals is ##\sqrt{5} \notin \mathbb{Q}## so S can't have a supremum. This is part of the reason that ##\mathbb{Q}## is incomplete.
That is, while ##\mathbb{Q}## obeys the ordering axioms, subsets of ##\mathbb{Q}## which are bounded above may fail to have a supremum which we can show using S.
Wow. You're awesome. Thanks so much for alleviating at least a small part of my vast incomprehension of this material. About 95% of me wants to burn this textbook then ingest like 5000mg of cyanide.
The field Q is not complete.
R is complete.
You're supposed to deal with the sup in R. The argument [itex]\sqrt{5}[/itex] is not in Q should only be applied to show that the set aforementioned has no sup over Q.
FAQ: Using The Completeness Axiom To Find Supremum and Saximum.
What is the Completeness Axiom?
The Completeness Axiom is a fundamental concept in real analysis that states that every non-empty set of real numbers that is bounded above (or below) has a least upper bound (or greatest lower bound). In other words, it guarantees the existence of a supremum (or maximum) for any set of real numbers.
How is the Completeness Axiom used to find the supremum and maximum of a set?
To find the supremum and maximum of a set using the Completeness Axiom, you first need to determine if the set is bounded above or below. If it is bounded above, you can use the axiom to prove the existence of a least upper bound, which is the supremum. Similarly, if the set is bounded below, you can use the axiom to prove the existence of a greatest lower bound, which is the maximum.
Can the Completeness Axiom be used for any set of real numbers?
Yes, the Completeness Axiom can be used for any non-empty set of real numbers, as long as the set is bounded above or below. This includes both finite and infinite sets, as well as closed and open intervals.
What are some applications of the Completeness Axiom in real analysis?
The Completeness Axiom is a fundamental tool in real analysis and is used in various applications, such as proving the existence of roots of equations, convergence of sequences and series, and continuity of functions. It is also used in the construction of the real numbers from the rational numbers.
Are there any limitations to using the Completeness Axiom to find the supremum and maximum?
One limitation of using the Completeness Axiom is that it only guarantees the existence of a supremum and maximum, but it does not provide a method for finding their exact values. In some cases, it may be difficult to prove the existence of these bounds using the axiom alone, and other tools and techniques may be needed.
