Using the drude equation to find the dielectric function
In summary, to use the liftgarbagez equation to compute the Casimir-Liftgarbagez force between two surfaces immersed in ethanol at a certain distance apart, you need to obtain the dielectric function for each surface and ethanol using the drude function with the plasma and relaxation frequencies obtained from Palik's Optical Constants of Solids. There is no specific frequency range mentioned in the paper, but solving the Drude equation over a range of frequencies in the visible light spectrum should cover most of the frequencies needed for the Casimir-Liftgarbagez force calculation.
OrigamiNinja
24
\\minerfiles.mst.edu\dfs\users\bjdphb\Desktop
I'm trying to use the liftgarbagez equation to compute the Casimir-Liftgarbagez force between two different surfaces immersed in ethanol at a certain distance apart.
I've never used or studied this equation before, and there are some things I don't know.
The main thing required for this equation is a dielectric function for each of the two surfaces and the ethanol.
The drude function is used with the plasma and relaxation frequencies of the material; these parameters are obtainable using Palik's Optical Constants of Solids vol. 1-5.
The drude equation is in the form e(w) = 1- ( wp^2/(w(w + iy)))
where e(w) is the dielectric function of frequency
wp is the plasma frequency
y is the relaxation frequency
ok, so my question is, the dielectric function can be solved at any frequency w. is there a particular frequency or range of frequencies to solve it for to be used in the Casimir-Liftgarbagez equation to determine the Casimir force at a certain distance between surfaces?
There is a paper that I am trying to follow to do these calculations. I'm including a link to it.
http://www.seas.harvard.edu/capasso/publications/Munday_PRA_78_032109_2008.pdf
The Drude equation is equation (10) in the paper and the Casimir Liftgarbagez equation I wish to solve at a given distance for given materials is equation (12).
The paper does not specify the frequency range at which the dielectric function needs to be solved, but I assume this would effect the results of the Casimir-Liftgarbagez force calculation. My suggestion would be to solve the Drude equation using a wide range of frequencies over the visible light spectrum (400nm to 800nm). This should cover most of the frequencies that contribute to the Casimir-Liftgarbagez force computation.
Related to Using the drude equation to find the dielectric function
1. What is the Drude equation and how does it relate to the dielectric function?
The Drude equation is a mathematical model that describes the behavior of electrons in a material. It is used to calculate the complex dielectric function, which is a measure of how a material responds to an electric field.
2. How is the Drude equation derived?
The Drude equation is derived from classical electromagnetism and the kinetic theory of gases. It assumes that electrons in a material behave like a gas and interact with the electric field in a similar way to particles colliding in a gas.
3. What are the limitations of using the Drude equation to find the dielectric function?
The Drude equation is a simplified model and does not account for quantum effects or the complex interactions between electrons in a material. It also assumes that the material is isotropic and does not take into account any anisotropy or crystal structure.
4. How is the Drude equation used in practical applications?
The Drude equation is often used in the study of metals and conductors, as it can provide valuable information about their electrical properties. It is also used in the design and optimization of electronic devices, such as transistors and circuit boards.
5. Can the Drude equation be applied to all materials?
The Drude equation is most applicable to materials with a high density of free electrons, such as metals and semiconductors. It is less accurate for insulating materials, as they have a lower concentration of free electrons and may have different mechanisms of electron behavior.
