Using the equation intensity = power/cross-sectional area
In summary, the intensity of the radiation 1m away from a 100W lamp, assuming it is a point source, is calculated by dividing the power by the surface area of a sphere, which is 4*Pi*r2. This is because the light is distributed uniformly over the surface area of the sphere, which is considered the cross-sectional area of the light. The equation uses the terms cross-sectional area and surface area interchangeably, depending on the context.
John421
Let's say we have the problem: A 100W lamp emits light in all directions. Assuming that the lamp is a point source, calculate the intensity of the radiation 1m away from the lamp.
The surface area of a sphere is :4*Pi*r2
The answer is intensity = 100w/4Pi = 7.96
Now what confuses me is that the answer is derived by intensity = power/surface area of the shape the wave makes when it spreads out.
Shouldn't cross-sectional area be the cross-sectional area of a sphere?
I don't see how 4*Pi*r2 is the cross-sectional area in this case.
4 pi r2 is the surface area of a sphere. Your light will be distributed uniformly over this area.
But then why does the formula say cross-sectional area instead of surface area?
This is the cross-section of the light with your sphere. It happens to be the whole sphere as you have a point-charge radiating in all directions.
If the question were to ask what the intensity of the light was at a screen 1m away from your light source, then you would use the surface area of that screen, not the surface area of your light source (just to be clear on what surface area you are using -- not the surface area of your light source). I just want to ensure you know that the equation uses the cross-sectional area (of the light) interchangeably with the surface area of the *thing* that the light is hitting.
Related to Using the equation intensity = power/cross-sectional area
What is intensity?
Intensity is a measure of the amount of energy or power per unit area. It is typically expressed in units of watts per square meter (W/m2).
What is power?
Power is the rate at which energy is transferred or converted. It is typically measured in units of watts (W) and represents the amount of energy per unit time.
What is cross-sectional area?
Cross-sectional area refers to the two-dimensional area that is perpendicular to the direction of energy transfer or propagation. It is typically measured in units of square meters (m2).
How is intensity related to power and cross-sectional area?
The equation intensity = power/cross-sectional area represents the inverse relationship between intensity, power, and cross-sectional area. As power increases, intensity increases, but as cross-sectional area increases, intensity decreases.
What are some real-world applications of this equation?
This equation is commonly used in fields such as optics, acoustics, and electromagnetism to calculate the intensity of energy waves. It is also used in industries such as laser technology, ultrasound imaging, and radio communication to optimize power and intensity levels for specific applications.
  • Mechanics
