Using the lift equation, can you make anything fly?
In summary: The lift equation is an entirely empirical relationship, and ##C_L## actually incorporates a lot of really complex physics. Typically, ##C_L## is determined through some combination of experiments and computations for a specific shape or family of shapes.
Quintijn van Heek
If I have a contraption with wings that weighs 120 kg, the wings in total are 2 meter squared, and I make it go 60 km/h, will it fly? According to the lift equation (L = (1/2) d v^2 a CL), it should, since
L=(1/2)*1.225*277.788*2*3.39 = 1176.789
Weight = 120 kg = 1176.789 N
L = lift = 1176.789 N
D = density = 1.225 kg/m^3
V = velocity = 16.667 m/s
V^2 = velocity squared = 277.788 m/s
A = area of wings = 2 m^2
CL = coefficient of lift = 3.39
If my calculations are correct, it should fly, right? Or am I forgetting something? I'm not really sure.
Likes Parth
Uh, well, sure, as long as you are ok with ignoring major considerations like stability/control, thrust/drag and structural integrity.
...and if you don't mind my asking, how much do you weigh...?
I'm not sure but it's quite possible that the area is meant "projection as seen from the front", not the actual size of the wings.
Also the CL looks quite optimistic but possible.
How do you maintain the speed? The drag may be fairly high and should be computed as well.
SlowThinker said:
I'm not sure but it's quite possible that the area is meant "projection as seen from the front"...
It's not; that's for drag.
Thanks. I weigh 55 kg
Not trying to make yourself fly, are you...?
Likes phinds
William Devane's character, Major Phil Clark, in Red Flag the Ultimate Game regarding the F-4 Phantom, "You can make a brick fly if you put large enough engines on it," or words to that effect.
Likes Quintijn van Heek and russ_watters
Well I'm not neccesarily making myself fly, i was just researching the lift equation and I was just wondering wether it waspossible. So then I worked all this out and well now I have an answer :). It was hypothetical though.
Here's some useful information about the lift equation and how some common theories explaining lift are wrong or incomplete:
https://www.grc.nasa.gov/www/K-12/airplane/presar.html
There are several other tracks here for drag, forces and torque and stability.
However, following the track for theories of lift they describe some incorrect theories:
https://www.grc.nasa.gov/www/K-12/airplane/right2.html
https://www.grc.nasa.gov/www/K-12/airplane/wrong1.html
https://www.grc.nasa.gov/www/K-12/airplane/wrong2.html
https://www.grc.nasa.gov/www/K-12/airplane/wrong3.html
https://www.grc.nasa.gov/www/K-12/airplane/bernnew.html
There's also a cool Paper Plane book by John Collins who holds the world record for longest paper plane flight. In the book, he describes the process of building the plane and the work that went into winning the Guinness award:
https://www.amazon.com/dp/1607743884/?tag=pfamazon01-20
and more on John COllins and his paper plane:
Likes bob012345
A lift coefficient of 3.39 is incredibly optimistic. Even with complicated multi-element airfoils, 2-2.5 is more typical as a Cl_max, although 3.4 is definitely possible. It's also worth noting that the drag at this Cl is likely to be quite high. You'd really want either more wing area or a higher speed to make this at all feasible.
A similar statement applies to boats. From a Mercury outboard motor ad in 1964:
I would not want to try that boat on a windy day...
Likes jedishrfu, Bystander, russ_watters and 1 other person
Sorry I couldn't resist...
Likes russ_watters, cjl, jedishrfu and 1 other person
Please note that "the lift equation" is an entirely empirical relationship, and ##C_L## actually incorporates a lot of really complex physics. Typically, ##C_L## is determined through some combination of experiments and computations for a specific shape or family of shapes. It's nearly impossible to just look at a random airfoil (or other) shape and guess its ##C_L##.
In principle, you could make any object fly as long as you had enough thrust pointed in the right direction, but it's not always feasible.
Likes bob012345
Indeed. Stunt planes at air shows have engines so powerful they can turn vertical and simply hover. When they turn horizontal, they merely pull themselves through the air.
In fact, because they do so many stunts upside down, their wings are symmetrical in cross-section (cambered top and bottom). The wings aren't needed for lift really, they're needed for stability and maneuvering.
WHAT SORCERY IS THIS
Did someone mention sorcery...
Aww you guys don’t know anything, the ETs have mastered lift best:
Likes jedishrfu
cjl said:
the "handle" is actually vertical and horizontal stabilizers, and the lawnmower deck is a (very stubby, low aspect ratio) wing. Elevons for control are attached to the back of the deck.
Yeah. I saw that. Clever.
[ EDIT ] good lord! It's a kit!
Likes jedishrfu
Actually the area used in the generic lift, drag relation of 1/2 x density x C x A x V^^2 is arbitrary since the coefficients of lift and drag are by experiment are referenced to the area dimensions selected. A classic text by Prandtl & Tiegens on Applied Hydro & Aerodynamics selected the largest projected area of the wing based on the chord and span for the representative area. Any representative area could be used and the determined coefficient would reflect that selection. Handbook of Fluid Dynamics by Streeter use the airfoil chord as a representative length for a unit wing span. Experimental work I have done required selections for various dimensions be made to determine the complicated unknown coefficients.
You can launch a ballistic missile horizontal from a submarine but why would you want to?
So can pigs fly with JATO.
I think the fact that the engine thrust can match the weight doesn't mean wings aren't needed for level flight. Normal planes can fly upside down also if the angle of attack is still positive but the airfoil isn't as efficient that way.
I disagree with your calculation assumptions because you can't know what the coefficient of lift is without knowing the design and even then it's very complex as others have pointed out. If your design worked at this speed then it by definition it would have that CL but you can't know that without at least simulations first.
But having said that, yes, in general you could make a small lightweight aircraft that worked at lower speeds. Here is an example;
https://www.wired.com/2012/06/electric-flynano/
You could google WIG planes (wing in ground effect).
Another possibility is to use the Magnus effect for the wings. I say that because theory says you can get very high lift for short wings using this effect. Very roughly, if each wing is a 0.5m diameter rotor one meter long, spinning at 20rev/second, forward motion of the craft moving at 16.67m/s would give lift equal to about your weight plus the 160kg machine if you designed it within the weight parameters. The rotors don't have to be massive or have big moments of inertia either if you design them not to. If your rotors were one meter in diameter, they would only have to spin at 5rev/second or 300 rpm. They don't need to be solid.
My suggestion is get access to a simulation program that does fluid dynamics and test your ideas on the computer to get a feel for how the numbers works out.
It isn't really arbitrary, though. You certainly could use the frontal area, for example, and the data would fit, but lift doesn't actually scale with that parameter unless all airfoils have the same ratio of frontal area to planform area. You would end up with relationships that aren't all that general. You are better off using the "correct" area so your relationships collapse onto one another more readily.
There is information available from NASA and other sources on airfoil design where the coefficient of lift has been calculated already for each configuration. Here is one source;
http://airfoiltools.com
Long before such free-flight wonders, control-wire stuff could make you look twice.
IIRC, one aero-modelling magazine even featured plans for a Snoopy(TM) kennel and pilot...
Related to Using the lift equation, can you make anything fly?
1. How does the lift equation work?
The lift equation is a mathematical formula that calculates the amount of lift generated by an object, such as an airplane or a bird, as it moves through a fluid, such as air. It takes into account factors such as the shape and size of the object, the speed at which it is moving, and the density of the fluid.
2. Can the lift equation be used to make anything fly?
The lift equation can be used to calculate the lift generated by any object moving through a fluid. However, whether or not an object can actually fly depends on many other factors, such as its weight, the strength of its materials, and the power of its propulsion system.
3. How is the lift equation used in aviation?
In aviation, the lift equation is used to design and optimize the shape and size of aircraft wings, as well as to calculate the amount of lift needed to keep an airplane airborne. It is also used to determine the most efficient speed and angle of attack for the aircraft to achieve maximum lift.
4. Can the lift equation be used for objects other than airplanes?
Yes, the lift equation can be used for any object moving through a fluid, not just airplanes. It is commonly used in the design of other types of vehicles, such as boats, submarines, and rockets, as well as in the study of animal flight.
5. Is the lift equation the only factor in determining whether something can fly?
No, the lift equation is just one factor in determining whether an object can fly. Other important factors include weight, thrust, drag, and the strength and design of the object's materials. Additionally, the lift equation does not take into account external factors such as wind speed and direction, which can also affect an object's ability to fly.
  • General Engineering
  • Mechanics
17K
  • Mechanical Engineering
