Using the Locked Rotor Test to find parameters of DC motor?
In summary: This is because the instantaneous voltage across the armature is given by$$V = RI_a + k\omega,$$where the armature current I_a is the same as the current through the locked rotor. Hence, the motor's back-EMF must be given by$$V_b = k\omega = V - RI_a.$$It's just a matter of rearranging this equation to express angular velocity in terms of the motor's electrical parameters and input voltage, then evaluate it for the given conditions.So, solving for ω, we get ω = (V - RI_a)/k. All the parameters on the right side are given, so we can just plug them in and evaluate.BT
mikehsiao789
A locked rotor test is performed on a permanent magnet DC machine with the following results:
Terminal Voltage 5 V DC
Input Current 10 A DC
Locked rotor torque. 20 Nm
a) Making suitable approximations deduce the effective rotor resistance in ohms?
b) Making suitable approximations deduce the torque constant kφ in Nm/A?
c) If a light running test was now performed with a terminal voltage of 50V DC what approximate shaft speed in rpm would you expect?
I did some calculations, however I am not sure if what I am doing is correct.
[/B]
Short circuit current at normal voltage
is the short circuit current at voltage
is the short circuit current at normal voltage
Short circuit power factor
is the total input power on short circuit
is the line voltage on short circuit
is the line current on short circuit
is the short circuit power factor
[PLAIN]http://upload.wikimedia.org/math/8/4/3/843762fe06455b51d90ae61f2ee1c042.png[URL='http://en.wikipedia.org/wiki/Blocked_rotor_test#cite_note-12'][12][/URL]
Leakage reactance
is the short circuit impedance as referred to stator
is the leakage reactance per phase as referred to stator
is the total copper loss
is the core loss
[/B]
a) V/I= R => 0.5 ohms
b)Torque = k*Ia => Torque/Ia = k = 20 N*m/10 = k = 2
c) w= k*v => 50v*2= 100 rpm
I am not too sure if these are correct, it would be great if someone can help! Thank you :)
It looks like you've copied in some equations from a Wikipedia page, but note that it deals with an induction machine, not a PM DC machine.
Your answers look correct to me. You could perhaps qualify them a bit by using your motor model, which I guess, in steady state, is given by:
V = RI_a + k\omega
What is it you're not sure about?
Edit:
I missed the (c) part, which you have the wrong answer for. You should consider what the back-EMF should be for it to balance the terminal voltage of 50 V.
Equations that involve power factor and leakage reactance per phase are for AC motors.
Your answer to (b) wil be correct when you give it units.
I think you have insufficient information to be able to answer part (c).
I assume 'light running test' is equivalent to 'no-load test', so it'll accelerate until the terminal voltage is balanced by its back-EMF, but otherwise, I'd agree.
Thanks guys! I was confused because I searched through my textbook and it said that the no-load test was only for the AC machines and didn't mention anything about the DC. Hence, I used those equations I found on Wikipedia. I assumed that for a locked rotor test, the w would be 0. so V=RIa and that would make a=0.5 ohms and then for C I have no idea how to approach it. Even with a back-emf (how would I even calculate that? haha) Thank you!
The motor will accelerate until its terminal voltage equals the back-EMF it's generating, because at that point there isn't any voltage to drive current into the armature, i.e. there's no torque to continue acceleration.
If the back-EMF is equal to ##k\omega##, what does that tell you the angular velocity ##\omega## is in steady state with a terminal voltage of 50 V?
Your approach would work, but it needs a different k. Had you preserved the units in your calculations, you would see that your calculation cannot possibly produce the answer, e.g.,
V/k ➜ volts per Newton metre, and this looks nothing like radians/sec or RPM. You'd need a different k, one having units of volts per radian/sec.
Related to Using the Locked Rotor Test to find parameters of DC motor?
1. What is the Locked Rotor Test and how does it work?
The Locked Rotor Test is a method used to determine the electrical and mechanical parameters of a DC motor. The motor is locked or prevented from rotating and a voltage is applied to the motor's terminals. The resulting current and voltage values are used to calculate the motor's parameters.
2. Why is the Locked Rotor Test important for DC motors?
The Locked Rotor Test is important because it allows us to accurately determine the parameters of a DC motor, such as resistance, inductance, and back EMF constant. These parameters are crucial in designing and controlling the motor's performance in various applications.
3. What are the benefits of using the Locked Rotor Test over other methods?
Compared to other methods, such as the No-Load Test, the Locked Rotor Test provides more accurate and reliable results. It also requires less equipment and can be performed easily on site without disassembling the motor.
4. Can the Locked Rotor Test be used for all types of DC motors?
Yes, the Locked Rotor Test can be used for all types of DC motors, including brushed and brushless motors. However, the test procedure may vary slightly depending on the motor's construction and size.
5. Are there any limitations to using the Locked Rotor Test?
The Locked Rotor Test may not provide accurate results for very small motors or motors with high starting torque. In such cases, alternative methods may be necessary to determine the motor's parameters.
