MHB Using the Method of Undetermined Coefficients to find a particular solution
shamieh
Note that the general solution to $y'' - y = 0$ is $y_h = C_1e^t + C_2e^{-t}$
In the following, use the Method of Undetermined Coefficients to find a particular solution.
a)$y'' - y = t^2$
So here is what I have so far
$y_p = At^2 + Bt + C$
$(y_p)'' = 2A$
Ive got $A = -1, B = 0 , C = 0$
so would the $y_p = -t^2$ be correct?
When you substitute $y_p$ into the given ODE, you obtain:
$$(2A)-\left(At^2+Bt+C\right)=t^2$$
or:
$$-At^2-Bt+2A-C=1t^2+0t+0$$
Equating coefficients, we obtain the system:
$$-A=1$$
$$-B=0$$
$$2A-C=0$$
And so we find:
$$(A,B,C)=\left(-1,0,-2\right)$$
Thus, we have:
$$y_p(t)=-\left(t^2+2\right)$$
Does this make sense?
a)$y'' - y = t^2$
$(y_p)'' = 2A$
so my mind has went blank...how do I solve this? $2A - At^2 + Bt + C = t^2$ Any advice would be great
I think it would be $A = 1/2, B= 0, C =0$
... may be that the solution is more simple You think...
$A = -1$
$B=0$
$2\ A + C = 0$
A and B are known... what is C?...
KInd regards
$\chi$ $\sigma$
YES! So $y_p = -t^2 - 2$
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
