Using the Variational Method to get higher sates
In summary, the Variational method can be used to approximate the ground state and energy of a Hamiltonian. If the ansatz is chosen carefully, the energy of the resulting approximation will be closer to the first excited state energy.
ExplosivePete
TL;DR Summary
An intro quantum course will teach you the Variational Method for approximating the ground state by minimizing an ansatz. But what about higher states?
In a typical quantum course we learn how to approximate the ground state of a particular Hamiltonian by making an educated guess at an ansatz with a tunable parameter then calculating the expectation energy for the ansatz. The result will depend on the tunable parameter if done correctly. Then we can minimize the energy with respect to that parameter, and that can give nice results approximating the ground state and energy. Cool stuff.
I have been wondering about what kind of algorithm we could cook up to find higher energy states. Say you have some Hamiltonian, H. We can apply the Variational method to get the ground state ψ0 and E0. Since the true energy states span the hilbert space, then we would hope that the expansion of ψ0 would mostly be composed of the true ground state. We could then apply the variational method again, but this time choose an ansatz, ψ1, which is orthogonal to ψ1. Assuming that ψ0 was a good guess, then ψ1 will be "mostly" orthogonal to the true ground state. Then the application of the variational method will result in an energy that will be closer to the first excited state energy. In fact, it would be easy to prove that if ψ0 is the exact ground state, then the energy of ψ1 will be bounded below by the first excited state energy.
This kind of has the feel of applying the Graham Schmidt process for finding orthogonal basis vectors, except the resulting basis is ordered by the energy. I assume there is some sort of algorithm out there to do this. The tricky part is how to handle the step of choosing the ansatz.
Let me know your thoughts and if you have seen something like this before.
The easier way of doing this is to start by picking a set of functions that you can guess are going to be close to spanning the ground state and the first excited state. You can then compute the matrix elements of the Hamiltonian in this subspace and you will get a 2x2 matrix that you can diagonalise to get approximations for the energies.
If you wish you can always let the functions in this procedure depend on some parameters and minimize the energies with respect to those parameters as well.
To avoid having the ansatz being "accidentally" orthogonal to the first excited state too, it's good to remember how the number of nodes depends on the level of excitation. At least this works in single-particle problems where there are no complications of making the wave function antisymmetric in the exchange of identical fermions.
Good point. There are a lot of nice tricks that would be nice to see summarized somewhere as far as techniques for choosing the ansatz. It is also useful to look at when the particle is in a "classically restricted region" (E < V(x)). In these regions, the wave function will be concave down (as easily shown from the Schrodinger equation).
Coming up with the trial functions can be a fun game, but unfortunately most assigned problems tell you what ansatz to use, which is all the fun. The rest is tedious calculation.
Related to Using the Variational Method to get higher sates
1. What is the Variational Method?
The Variational Method is a mathematical technique used to approximate the energy of a quantum mechanical system. It involves choosing a trial wavefunction and minimizing the energy expectation value to find the best possible approximation to the true energy of the system.
2. How does the Variational Method work?
The Variational Method works by using a trial wavefunction, which is a mathematical function that describes the behavior of a quantum mechanical system. This function is then used to calculate the energy expectation value, which is the average energy of the system. By minimizing this value, the Variational Method finds the best possible approximation to the true energy of the system.
3. What is the advantage of using the Variational Method?
The advantage of using the Variational Method is that it can provide a good approximation to the true energy of a quantum mechanical system, even if the exact solution is unknown. This makes it a useful tool for studying complex systems that cannot be solved analytically.
4. Can the Variational Method be used for any system?
Yes, the Variational Method can be applied to any quantum mechanical system. However, the accuracy of the approximation depends on the choice of the trial wavefunction and the complexity of the system.
5. Are there any limitations to using the Variational Method?
One limitation of the Variational Method is that it can only provide an upper bound for the true energy of a system. This means that the approximation may not be exact, but it will always be equal to or greater than the true energy. Additionally, the accuracy of the method depends on the quality of the trial wavefunction chosen.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
