Using time-step analysis to simulate Scheils equation
  • Thread starter Krikor Hagopian
  • Tags
    Analysis
In summary, the conversation discusses the use of excel for numerical analysis and the issue of diverging results compared to Scheils equation. The speaker has uploaded an excel file and suggests checking for negative exponents and verifying the implementation of Scheils equation.
Krikor Hagopian
Using excel, I tried to do a numerical analysis to get the same results as scheils equation. The problem is that the two concentration profiles start diverging at the end. The numerical analysis is offcourse based on time-step analysis.
I have uploaded the excel file.
Much Gratitude,
  • System.xlsx
Its going to take too much time to try and reverse engineer your excel file.
How are you going about your numerical analysis, which columns are being plotted? It looks like the data diverges after the first 50 points or so, sharing only the first point in common.
Based off of the graph your problem probably lies in a denominator getting really big; check for any exponents that are negative and try to verify that your implementation of the Scheils equation is correct.
FAQ: Using time-step analysis to simulate Scheils equation
1. What is time-step analysis?
Time-step analysis is a numerical method used in scientific simulations to divide a continuous process into smaller time intervals, or "steps." This allows for the accurate modeling of complex systems by taking into account time-dependent changes and interactions between various components.
2. How is time-step analysis used to simulate Scheil's equation?
Scheil's equation is a mathematical model used to predict the solidification behavior of alloys. Time-step analysis is used in this context to simulate the solidification process by dividing it into small time intervals. This allows for the accurate calculation of the alloy's composition and microstructure at each step.
3. Why is time-step analysis important in simulating Scheil's equation?
Scheil's equation involves complex, time-dependent phenomena such as diffusion and nucleation, which cannot be accurately predicted without considering small time intervals. Time-step analysis allows for a more detailed and precise simulation of these processes, leading to more accurate results.
4. What are the limitations of using time-step analysis to simulate Scheil's equation?
One limitation is the computational cost. As the number of time steps increases, so does the time and resources required for the simulation. Additionally, time-step analysis assumes a constant composition and temperature throughout each time interval, which may not always be the case in real-world scenarios.
5. How can the results of a time-step analysis simulation of Scheil's equation be validated?
The results of a time-step analysis simulation can be compared to experimental data or other simulation results to validate its accuracy. Additionally, sensitivity analysis can be performed by varying the time step size and observing the impact on the results, ensuring the simulation is not overly dependent on the chosen time step.
