Using triangulation to find distance....
In summary, the triangulation method uses multiple angle measurements to determine the distance between two objects, rather than relying on their apparent size. This can be achieved by measuring the angle from a single fixed point to two different points on the object, or by measuring the angle from two points to a single point on the object. Triangulation is commonly used in surveying and parallax measurements.
ViolentCorpse
190
Hi,
There's something I'm having difficulty understanding in the triangulation method of finding distances. Just trying to understand the principle.
If two objects have the same apparent size and are placed at different distances, wouldn't our measurement of angles be the same for both?
E.g the sun and moon both have an approximately equal apparent size as viewed from Earth. But the sun is much farther away than the moon is. I can't visualize how, if measurements are made, different values of angles would be attained for the two cases i.e moon and sun.
I don't know why my intuition is compelling me to believe that if the apparent sizes of two objects are same, the angles will also be the same no matter how far apart the objects are...
Mathematics news on Phys.org
Dr. Courtney said:
Dear doctor, I understand how triangulation basically works. I'm just confused when I consider that it is possible for two objects to be placed at different locations and be different sizes and yet have the same angular size. Now, if these objects are triangulated, would they both form the exact same angles, since they have the same angular size? If they do, then we will have exactly identical triangles and there distance would also turn out to be the same, which is not actually true...
I don't think you do, because triangulation doesn't use the apparent size of an object - in fact if an object is not a point you need to select a fixed point on the object to use for both angular measurements.
Yeah I probably don't.
So, you're saying that two different objects located at different distances will form different angles (if we select a fixed point on each object for making the measurements) irrespective of their apparent size?
One way of doing triangulation is to measure the angle from a single fixed point "here" to two different points a known distance apart on an object over there. This is the principle on an old style surveyor's transit. The surveyor measures the angle to one marker high on a survey pole and the angle to another marker low on the survey pole. A little trig and *voila* -- the distance from transit to pole is known. Using this approach, the apparent size of the moon is only useful for measuring the range to the moon if you know its actual size.
The other way of doing triangulation is to measure the angle from two points a known distance apart "here" to a single object (or to a single point on an object) "over there". This is a principle behind a coincidence rangefinder (https://en.wikipedia.org/wiki/Coincidence_rangefinder). It is also the essential principle behind parallax measurements. Using this approach, the apparent size of the moon is irrelevant.
Likes ViolentCorpse
You are thinking that the left line is pointing at the left side of the distant objects and the right line is pointing at the right side of the objects. You are correct that then the angles could be the same. But if you point both lines at the left side of the objects, the closer object would make a different angle than the farther farther object. That is what you do when you triangulate. You pick a single point on the object and point both lines at that single point.
Likes ViolentCorpse
Thanks a lot guys! :)
But if you only use two objects for triangulation, wouldn't there be 2 answers?
Perhaps we should use 3 objects/points for triangulation, that's why it is called triangulation.
And in 3D space we use 4 objects/points for 'triangulation'. Is this true?
No, why do you think that?
No, it's called triangulation because bearings only need to be measured from or to two different points to locate a third point - these three points form a triangle (not to be confused with the "triangle of uncertainty" when three bearings are used).
No, two points are still sufficient (there is one more unknown but 2 more measurements as we have elevation angles as well as direction).
Is this why?
But it's hard to draw three pictures. Has to use some graphic software other than Microsoft Paint.
Stephanus said:
Is this why?
Triangulation is not about using multiple distance measurements to determine position. [That's how GPS works]. Triangulation is about using multiple angle measurements.
Likes pbuk
Oh, I'm so sorry. I was wrong. Is this like determining paralax?
https://en.wikipedia.org/wiki/Triangulation
Yes.
Likes pbuk
Related to Using triangulation to find distance....
1. How does triangulation work to find distance?
Triangulation is a method used to calculate distance by using three known points in a triangle. By measuring the angles of the triangle and knowing the distance between two of the points, the distance to the third point can be calculated using trigonometry.
2. What tools are needed for triangulation?
To perform triangulation, you will need a measuring tool (such as a tape measure or ruler) to measure the distance between two points, and a protractor or angle measuring device to measure the angles of the triangle.
3. Can triangulation be used for long distances?
Yes, triangulation can be used for long distances. However, as the distance increases, the accuracy of the measurements and calculations decreases. In order to increase accuracy for longer distances, more points and angles may need to be included in the triangulation process.
4. What are some common applications of triangulation?
Triangulation is commonly used in surveying and navigation to find the distance between two points. It is also used in astronomy to calculate the distance to stars and other celestial objects. Triangulation is also used in mapping and cartography, as well as in GPS technology.
5. Are there any limitations to using triangulation?
Yes, there are some limitations to using triangulation. One limitation is that it only works for finding distance in a two-dimensional space. Additionally, triangulation is only accurate if the three points used are in a straight line. If there is any error in the measurements or angles, it can greatly affect the accuracy of the calculated distance.
  • Biology and Medical
