Using trig substitution or partial fractions?
In summary, trig substitution should be used when you encounter the sum or difference of 2 squares, which can be identified by the Pythagorean theorem. This method involves labeling an angle and expressing all terms as trigonometric functions in a right triangle. However, there may be other methods, such as partial fractions, that can also be used for certain integrations.
JessicaJ283782
41
When would you use trig substitution vs. partial fractions? I know partial fractions is when you have a polynomial over a polynomial, but some of the problems in the trig substitution section in my book had polynomial over polynomial and used trig substitution?
A good general rule is that any time you see the sum or difference of 2 squares you should think trig substitution. The sum or difference of 2 squares looks like the Pythagorean theorem so you have a right triangle. Label an angle and express all terms as trigonometric functions of that angle. There certainly are multiple methods for many integrations.
Related to Using trig substitution or partial fractions?
1. What is trig substitution and when is it used?
Trig substitution is a technique used to simplify and solve integrals involving square roots of quadratic expressions. It is typically used when the integral contains a term in the form of √(a^2 − x^2), where a is a constant.
2. How do you perform trig substitution?
To perform trig substitution, you first identify the appropriate trigonometric substitution by comparing the square root expression to the standard trigonometric identities. Then, you substitute the trigonometric function for the variable, making additional substitutions as needed to simplify the integral. Finally, you solve the integral using trigonometric identities and integration techniques.
3. What are the common types of trig substitutions?
The most common types of trig substitutions are u-substitution, reverse u-substitution, and double angle substitution. U-substitution involves substituting √(a^2 − x^2) with a trigonometric function such as sinθ or cosθ. Reverse u-substitution involves substituting a trigonometric function for a variable in the form of √(x^2 − a^2). Double angle substitution involves using double angle identities to rewrite the integral in a form suitable for trig substitution.
4. What is partial fractions decomposition?
Partial fractions decomposition is a method used to break down a rational function into simpler fractions. It is typically used to simplify integrals involving rational functions. The decomposition involves finding the appropriate coefficients for each term in the fraction by equating the numerator and denominator on both sides of the equation.
5. When is partial fractions decomposition used?
Partial fractions decomposition is used when the integral contains a rational function that cannot be easily integrated using other techniques. It is also used to solve systems of linear equations and to find Laplace transforms in mathematics and in engineering applications.
  • Calculus
  • Calculus
  • Calculus
