Using undetermined multipliers in Lagrangian Mechanics
In summary, the conversation discusses using Lagrangian equations with undetermined multipliers to solve for the motion of a disc rolling down an incline. Three equations are needed to solve for the three unknowns (y, θ, λ), including the equation of constraint. The idea is to introduce auxiliary degrees of freedom and minimize the corresponding action. It becomes clear that the constraint equation is necessary to obtain unique solutions for the initial-value problem. Both methods of solving the problem yield the same solutions and describe the same physics.
gulfcoastfella
An example problem in Chapter 7 of "Classical Dynamics of Particles and Systems" by Marion, Thornton uses Lagrangian equations with undetermined multipliers to solve for the motion of a disc rolling down an incline. The resulting Lagrangian equations are:
Mg sin α - M d2y/dt2 + λ = 0
MR2 d2θ/dt2 - λR = 0
y = R θ (equation of constraint)
I understand how these equations were developed, and I realize that three unknowns (y, θ, λ) require three equations. I don't feel comfortable, though, with including the equation of constraint as one of the equations when it's already incorporated into the other two equations as a partial derivative. Can anyone make me feel better about this?
The idea (for the most simple case of holonomous constraints) is as follows: You have a set of generalized coordinates ##q^j## and a set of constraints
$$f_k(q^1,\ldots,q^n;t)=0, \quad k \in \{1,2,\ldots,m \}.$$
One way to describe the dynamics is to introduce a new set of independent variables ##Q^k##, ##k \in \{1,2,\ldots,n-m\}##, write the Lagrangian (action) in terms of these independent variables and then write down the equations of motion, following from the stationarity of the corresponding action.
Another way is to introduce auxiliary degrees of freedom ##\lambda^k## (Lagrange multipliers) and make up an action, depending on the ##q^j## and ##\lambda^k## as generalized coordinates and define the action as
$$\tilde{L}=L(q,\dot{q};t)-\sum_{k=1}^m \lambda^k f_k(q;t).$$
Then you minimize the corresponding action
$$A[q,\lambda]=\int_{t_1}^{t_2} \mathrm{d} t \tilde{L}(q,\dot{q}\lambda;t).$$
The variation with respect to the ##q## gives ##n## 2nd-order differential equations, and the variation with respect to the ##\lambda## gives you back the ##m## constraint equations. All together you have ##(n+m)## equations for ##(n+m)## unknown functions ##q## and ##\lambda##, which lead to unique solutions for the initial-value problem, if no pathologies occur.
Try to solve your example, and it should become very clear immediately that, of course, you need the constraint equation to have a complete set of equations to be solved for the three independent degrees of freedom ##y##, ##\theta##, and ##\lambda##.
In this case, it's of course also trivial to solve the constraint to eliminate one degree of freedom instead of introducing the Lagrange multiplier. You'll see that you get, of course, the same solutions and describe the same physics, using both methods.
FAQ: Using undetermined multipliers in Lagrangian Mechanics
What are undetermined multipliers in Lagrangian Mechanics?
Undetermined multipliers are variables used in Lagrangian Mechanics to account for constraints that cannot be explicitly expressed in the system's equations of motion. They are used to enforce these constraints and ensure that the system's equations of motion are satisfied.
How are undetermined multipliers calculated?
Undetermined multipliers are typically calculated using the method of Lagrange multipliers. This involves taking the partial derivatives of the system's Lagrangian with respect to the constraints and setting them equal to the Lagrange multipliers. The values of the multipliers can then be solved for and used in the system's equations of motion.
What is the purpose of using undetermined multipliers in Lagrangian Mechanics?
The use of undetermined multipliers allows for the inclusion of constraints in the equations of motion, which may not be easily expressed otherwise. This allows for a more accurate representation of the system and can lead to more precise predictions and calculations.
Can undetermined multipliers be used in all types of systems?
Undetermined multipliers can be used in any system that can be described using Lagrangian Mechanics. This includes mechanical systems, electrical systems, and even quantum systems. However, the method of calculating and using the multipliers may vary depending on the type of system.
Are undetermined multipliers unique to Lagrangian Mechanics?
No, the concept of using multipliers to enforce constraints can also be found in other branches of physics, such as Hamiltonian Mechanics. However, the specific method of using undetermined multipliers in Lagrangian Mechanics is unique to this branch of physics.
