Using Variational Principle to solve ground state energy
1missing
A certain Hamiltonian can be expressed as: ##\hat H = | \varphi_1 \rangle \langle \varphi_1| + 2 | \varphi_2 \rangle \langle \varphi_2| + 3 | \varphi_3 \rangle \langle \varphi_3| ##
where, ##| \varphi_1 \rangle## , ##| \varphi_2 \rangle## , ##| \varphi_3 \rangle## are normalized but not fully orthogonal.
##\langle \varphi_1 | \varphi_2 \rangle = \langle \varphi_2 | \varphi_1 \rangle = \langle \varphi_2 | \varphi_3 \rangle = \langle \varphi_3 | \varphi_2 \rangle = \frac {1} {2}##
##\langle \varphi_1 | \varphi_3 \rangle = \langle \varphi_3 | \varphi_1 \rangle = 0##
1: ##E_\phi = \frac { \langle \phi | \hat H | \phi \rangle } { \langle \phi | \phi \rangle } ##
2: ##\sum_{j=1}^n (H_{ij} - ES_{ij} ) C_j = 0## , i = 1, 2,..., n
First I picked an arbitrary state ##|ϕ⟩=C_1|φ_1⟩+C_2|φ_2⟩+C_3|φ_3⟩## and went to use equation 1. Realizing my answer was a mess of constants and not getting me closer to a ground state energy, I abandoned that approach and went with equation two.
I proceeded to calculate the following matrix:
##\begin{pmatrix}
( \frac {3} {2} - E) & ( \frac {3} {2} - \frac {E} {2} ) & ( \frac {1} {2} ) \\
( \frac {3} {2} - \frac {E} {2} ) & ( 3 - E ) & ( \frac {5} {2} - \frac {E} {2} ) \\
( \frac {1} {2} ) & ( \frac {5} {2} - \frac {E} {2} ) & ( \frac {7} {2} - E )
\end{pmatrix}\vec C = 0##
Calculating the determinant, I end up with ##E^3 - 6E^2 + 9E - 3 = 0## which doesn't seem to have a rational solution. I must've gone through the calculation half a dozen times now, and confirmed with my professor that equation 2 was the one I should use, but I'm just not seeing how I'm supposed to find a solution.
Why do you expect the solutions to be rational? Or did you mean real instead of rational? The equation does have 3 real solutions.
I don't see how any variational method is being used here.
He usually models his exam questions off the homework problems he assigns. If he gave this problem on the exam there wouldn't be any way for me to solve for those roots, which made me think I messed up somewhere. If there were at least one integer solution, that term could be factored out by polynomial long division and I'd be left with a solvable quadratic for the other two.
He called the method "trial states as linear combinations of basis states". He starts with the variational principle, takes the derivative with respect to Ci, and sets it to zero. From that he derives equation 2.
OK, that sounds good. I checked the entries for your matrix and the equation coming from setting the determinant equal to zero. I get the same results. I don't see anything wrong with your work.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
