V * grad(V) = grad(V^2/2) - rotor(omega)
In summary, the equation states that the product of a scalar field \( V \) and its gradient \( \text{grad}(V) \) is equal to the gradient of half the square of that field \( \text{grad}(V^2/2) \) minus the rotational or curl component represented by \( \text{rotor}(\omega) \). This relationship connects scalar fields, their rates of change, and rotational effects in a mathematical framework.
Rikyuri
Hi, while studying for my aerodynamics class, I encountered this equivalence that my professor gave us as a vector identity:
\mathbf{V} \cdot \nabla \mathbf{V} = \nabla\left(\frac{V^{2}}{2}\right)-\mathbf{V} \times \boldsymbol{\omega}
where ## \boldsymbol{\omega} = \nabla \times \mathbf{V} ##I tryed to expand the operator and found that ## \mathbf{V} \cdot \nabla \mathbf{V} = \nabla(\frac{V^{2}}{2}) ## but that can't be true.
I really don't understend how ## \nabla \times \boldsymbol{\omega} ## fits into the equivalence.
If someone can explain how this works, it would be great.
PS: I hope that the LaTeX insertions work; if not, how do you insert LaTeX code in a post? (solved)
Edit: Latex insertion correction
You put it between ## ... ## for inline or between $$ ... $$ for outline.
Likes Rikyuri
Be careful as ## \sum_i v_i \partial_i v_k \neq \sum_i v_i \partial_k v_i ##. You should use parentheses, here ##\mathbf V \cdot \nabla \mathbf V## means ##(\mathbf V \cdot \nabla)\mathbf V##. I would start from ##\mathbf V\times \nabla \times \mathbf V##. What techniques do you know ? Do you know Levi-Civita identities?
Likes DeBangis21 and dextercioby
Oh, so it is the divergence, not the gradient. I don't really know Levi-Civita identities; I've only heard about them.
Regarding the techniques, I have knowledge of Calculus II.
If can be usefull I started to use Einstein notation for this class, sometimes I struggle a bit with it, but I can uderstand it. Thanks a lot for the help.
It is not even the divergence or gradient, it is the "vector-dot-del" (##\mathbf V \cdot \nabla ##) operator. If ##\mathbf V = (v_x,v_y,v_z)## then
$$(\mathbf V \cdot\nabla)\mathbf V = (v_x \partial_x+v_y \partial_y+v_z \partial_z)\mathbf V =\begin{pmatrix}[v_x \partial_x+v_y \partial_y+v_z \partial_z]v_x\\
[v_x \partial_x+v_y \partial_y+v_z \partial_z]v_y\\
[v_x \partial_x+v_y \partial_y+v_z \partial_z]v_z\end{pmatrix} $$
Compare with
$$\nabla \left(\frac12 V^2\right)=\begin{pmatrix}
v_x \partial_x v_x+v_y \partial_x v_y+v_z \partial_x v_z\\
v_x \partial_y v_x+v_y \partial_x v_y+v_z \partial_y v_z\\
v_x \partial_z v_x+v_y \partial_z v_y+v_z \partial_z v_z\\
\end{pmatrix}$$
which is totally different.Which calculus identities do you know? You can also just write it in components as I did and see if the relation holds.
Likes PhDeezNutz, Delta2 and dextercioby
Not much:
$$\nabla \times \nabla f = 0; \nabla \cdot \nabla \times f = 0$$
Those are the only one I remember using a part for this new one.
Rikyuri said:
Not much:
Then I suggest that you just calculate all 3 components of $$\mathbf V \times (\nabla \times \mathbf V)$$ and compare with the other too. There is no easy calculation without other calculus identities.
[Note to mentors: can the title of this thread be changed to (V dot del)V=grad(V^2/2)-(V cross omega)?]
Likes Rikyuri
