V, I, R in series circuit confusion
In summary, the voltage increases slightly when increasing the length of the wire, but current should decrease.
JoeN
I'm doing coursework on a circuit experiment we performed in class. I'm pretty sure the results are wrong or flawed, but we were testing the effect of increasing the length of wire on the resistance. I had a voltmeter about the wire, a cell, an ammeter, and completed the circuit by attaching the croc. clips to the wire...
Of course, the resistance should increase and the current decrease, but should the voltage increase, as it did in my experiment? And should it increase enough to also make the current increase despite the higher resistance? I know that more work is needed to push the charge through the wire if you increase its length, so in theory the wire's potential difference should increase (?) but I'm not so sure the current should increase... This didn't occur in the preliminary data I carried out either.
I'm not sure about the voltage of the cell. Well, I know it was 1.5V but it had been used enough to make that irrelevant.
Oops, wrong forum. Sorry about that
It should increase slightly, yes.
No. Current should decrease.
Can you post your measurements? These could help. I can think of several reasons for your measurements, but I might be able to eliminate some of them if I saw your data.
Now, why should the voltage increase as you increase the resistance? Imagine that you have 2 resistors of 10 Ohm each in series with 3V applied across. You have 20 Ohms of total resistance, giving you current of 0.15A. And that gives you 1.5V across each resistor. Now say, I increase resistance of one of these to 20 Ohm. That means total is now 30 Ohm, current drops to 0.1A, and the 20 Ohm resistor has 2V across it now.
Wire you are measuring across isn't the only thing with resistance. There are other wires and battery's own resistance. So when you increase resistance of the wire, more of the battery's applied voltage is dropped across the wire. Hence, higher voltage measurement. But the current should only decrease. Unless, something else is going on.
My preliminary data:
length of wire V A1 A2 mean ohms
10 0.28 1.20 1.25 1.23 0.23
20 0.24 1.21 1.22 1.21 0.20
30 0.32 1.10 1.16 1.13 0.28
40 0.30 1.11 1.13 1.12 0.27
50 0.39 0.98 0.97 0.98 0.40
This experiment followed my expectations: V increased slightly, A decreased, R increased (although I think the R and A should have increased and decreased a lot more?). And thanks for that explanation.
L.O.W V A1 A2 mean ohms
10 0.06 0.64 0.68 0.66 0.09
20 0.08 0.62 0.65 0.64 0.13
30 0.10 0.70 0.72 0.71 0.14
40 0.12 0.72 0.71 0.72 0.17
50 0.14 0.77 0.75 0.76 0.18
And this is where it messes up. I performed both experiments in the same way, so my initial conclusion was a mistake in the circuit or faulty equipment. Is there another conclusion?
Sorry for the late reply!
Shouldn't your voltage equal the applied voltage from your cell? Or are you not able to develop voltage very well across a conductor?
true, you can't get more voltage out than what you put into a passive circuit like that
Dave
Both sets look very strange.
First of all, it looks like the battery might be dying. That alone could explain the increases in current. If you give a dying battery a bit of time, ti recovers a bit. So the internal resistance can decrease a bit. That could explain your data.
Second part, I don't think your contacts were very good. You simply shouldn't be getting that kind of resistance dependence on length. However, if there was significant additional resistance on clips, it fits.
There are two things you can do to significantly improve this experiment.
1) Put a 5-10 ohm resistor in series with the wire. This will reduce the current through the whole thing, and tax the battery a lot less.
2) Get more data points with different lengths. The range of 10-50 (mm?) is fine. Then plot all these points resistance vs length. Try to fit a curve that looks like R = k*L + R0 through these points for some constants k and R[/sub]0/sub]. Assume that this R0 is due to bad contacts. This way, you can predict the "real" dependence of resistance on length via the remaining terms, R = k*L. Alternatively, you could just subtract off this R0 from your data at this point.
I'm not in a position to perform the experiments again, unfortunately, I just have to evaluate the data.
1) Battery dying is likely. They have probably been used many times before I did the experiment. So a dying battery can eventually recover some voltage and decrease in resistance for a higher current?
2) "You simply shouldn't be getting that kind of resistance dependence on length" - you mean the resistance is too great a change, or too small a change? Is the resistance not proportional to the length of the wire?
Yes, that's what bothering me about resistance measurements. There could be any number of reasons for this, but I suspect contact resistance. In which case, you have a somewhat noisy bias to your resistance measurement.
Linear regression might still give you a reasonable fit. Though, more data points would help a lot.
Do you by any chance know the material and diameter of the wire? And the lengths, are they in mm? It'd be easy enough to compare results to expected value if these things are known.
Related to V, I, R in series circuit confusion
What is the meaning of V, I, R in a series circuit?
V, I, and R are symbols used to represent voltage, current, and resistance, respectively, in a series circuit. They are measurements of the electrical properties of the circuit and are used to calculate various values, such as power and energy.
What is the difference between voltage, current, and resistance in a series circuit?
Voltage (V) is the potential difference between two points in the circuit, measured in volts. Current (I) is the flow of electric charge through the circuit, measured in amperes. Resistance (R) is the opposition to the flow of current, measured in ohms.
How are V, I, and R related in a series circuit?
In a series circuit, the voltage across each component is the same, and the total voltage is equal to the sum of the individual voltages. The current through each component is the same, and the total current is equal to the individual currents. The total resistance is equal to the sum of the individual resistances.
What happens to V, I, and R when components are added in a series circuit?
When components are added in a series circuit, the total voltage increases while the total current stays the same. The total resistance also increases, as each component adds to the overall resistance of the circuit. This relationship can be represented by the formula V=IR.
How can I calculate V, I, and R in a series circuit?
To calculate V, I, and R in a series circuit, you can use Ohm's Law, which states that V=IR. This means that voltage is equal to the current multiplied by the resistance. You can also use Kirchhoff's Voltage Law, which states that the sum of the voltages in a closed loop is equal to zero. Additionally, you can use the formulas for calculating total voltage and resistance in a series circuit, which are Vt=V1+V2+... and Rt=R1+R2+..., respectively.
  • Electrical Engineering
  • Other Physics Topics
  • New Member Introductions
