V Space With Norm $||*||$ - Fourier Series
In summary, the conversation is about a question regarding the convergence of a sequence in a space with a norm. The question asks to prove that if the sequence converges to two different vectors, then those vectors must be equal. The problem is not clear on which norm and definition to use, as the norms mentioned are just specific examples and the question asks to show it for an arbitrary norm. The conversation also includes a discussion on how to write mathematical expressions on the platform.
physics1000
104
I wrote below what is my question exactly, no need for answer, the question is not explainable well.
no equations here. only defintion, which we have not learned and I dont know what norm they want...
Hi, a question regarding something I could not really understand
The question is:
Let V be a space with Norm $||*||$
Prove if $v_n$ converges to vector $v$.
and if $v_n$ converges to vector $w$
so $v=w$
and show it by defintion.
The question is simple, the thing I dont understand, what definition? what norm exactly? we learnt only norm $L^1$ and $L^2$ and $L^\infty$ which is uniform convergence.
Please tell me what I wrote above.
EDIT: I dont know how to write latex here, at MSE its with $$, here it wont work.
The definition of a norm. The norms you mentioned are just specific examples of norms. You need to show it for an arbitrary norm.
Likes vanhees71
Well, I dont really know what is arbitary norm, we have not learned it :\I dont know what is the definition also, we learnt only what I said above.
If I knew the defintion of arbitrary norm, the question is easy, my problem is understanding what is the thing they want from me, I dont know how they expect us to solve something we have not learned...
physics1000 said:
HI thanks, I saw this already.
Definitions should be with epsilon. I dont see it there. that why i skipped it.
When I mean definition. I mean definition of how to prove.
Like for limit, there is
for all $\epsilon > 0 $, exist $n_0$ such that... and such
physics1000 said:
Homework Statement:: I wrote below what is my question exactly, no need for answer, the question is not explainable well.
Relevant Equations:: no equations here. only defintion, which we have not learned and I dont know what norm they want...
The question is:
so $v=w$
Sounds as if you should prove the uniqueness of limits according to an arbitrary norm topology.
... which is a bit strange to say. If something is true by definition, then there is nothing to show. If something has to be shown, then it can be used as a definition. I would phrase the problem as:
Show that ##\;\text{ IF }\;\lim_{n \to \infty}v_n=v\;\text{ AND }\;\lim_{n \to \infty}v_n=w\;\text{ THEN }\;v=w.##
Step 1: What does ##\lim_{n \to \infty}v_n=v## mean?
Step 2: Use the triangle inequality to show ##\lim_{n \to \infty}\|v -w\|=0.##
Just replace $ by ## for inline codes, and use $$ for extra lines.
Here is explained how you can type formulas on PF: https://www.physicsforums.com/help/latexhelp/
Likes vanhees71 and physics1000
Show that ##\lim_{n \to \infty}v_n=v\text{ AND }\lim_{n \to \infty}v_n=w\text{ THEN }v=w.##
Hi, Thanks alot!
The problem is, you told me how to answer it, but isnt there any definition? like the limit with epsilon? or definition for uniform covnergence with epsilon also?
it sounds really weird for me there aint any formal definition for it.
By saying definiton, I mean ( I will take for example the limit ):
for all ##\epsilon > 0##, there exist a natural number ##N## such that for all ## n>N## we have ##|an-L|<\epsilon ##
If you saw that already why do you claim not to know what an arbitrary norm is? An arbitrary norm is any function that satisfies that definition. Your task is to show that — given the norm topology — a sequence converges to a single unique point (if it converges at all).
ahh, my bad english comes here.
when you say, a sequence converges to a single unique point, you mean the ##||u-v||=0##? What fresh said?
physics1000 said:
Hi, Thanks alot!
The point is: In step 1 you have to make a definition in order to explain what convergence even means. In step 2, you show that limits are unique, which again means, that the definition in step one is well-defined.
In other words: In order to make sense of step 1, you need to show step 2.
ahh my bad english...
I will try to understand it, thanks!
You gave me enough information for me to try to solve it now, I will update :)
Managed to solve it, problem is what is the defintion they want?
I showed like that:
##||v-w|| = ||v-v_n +v_n - w|| <= ||v_n - v|| + ||v_n - w|| ##, now as limit of n goes to ##\infty## we get zero.
problem is, again, the definition, what definition they want?
I showed like that:
The definition is
\lim_{n \to \infty}v_n = v \quad :\Longleftrightarrow \quad \lim_{n \to \infty}\|v_n-v\|=0
In order to make sense of ##v_n \longrightarrow v## we need a distance: ##v_n## gets closer and closer to ##v.## What is closer? That's the part where the norm steps in. ##v_n## is closer to ##v## than ##v_m## if ##\|v_n-v\|<\|v_m-v\|.## This transports the uniqueness of the distance limit in ##\mathbb{R}## to the limit in ##(V\, , \,\|\;.\;\|).##
Your explanation above is the core of the solution, but you should add the technical details, the epsilontic.
Likes physics1000
fresh_42 said:
The definition is
Regarding the limit, its pretty obvious no? I will mention in anyway.
regarding the distance, to be honest, I havent saw this formula since linear algebra 2, I dont think we need to know it.
Regarding the epsilontic, thats my problem, the question, which epsilon? because each thing has its own definition.
there aint any definition for the limit of ##||v-w|| = 0##
sorry if I am making you crazy, I really dont understand what you mean by the definition of epsilon that I am trying to find out.
We know ##\displaystyle{\lim_{n \to \infty}v_n=v},## i.e. for any given real, positive number ##\varepsilon >0,## there is a natural number ##N(\varepsilon)\in \mathbb{N}## depending on ##\varepsilon ## such that ##\|v-v_n\|<\frac{\varepsilon }{2}## for all ##n>N(\varepsilon ).##
We know ##\displaystyle{\lim_{n \to \infty}v_n=w},## i.e. for any given real, positive number ##\varepsilon >0,## there is a natural number ##M(\varepsilon)\in \mathbb{N}## depending on ##\varepsilon ## such that ##\|v_n-w\|<\frac{\varepsilon }{2}## for all ##n>M(\varepsilon ).##
Hence for all ##n>\max\{N(\varepsilon ),M(\varepsilon )\}## we get (by the triangle inequality of the norm)
\|v-w\|=\|v-v_n+v_n-w\|\leq \underbrace{\|v-v_n\|}_{<\frac{\varepsilon }{2}}+\underbrace{\|v_n-w\|}_{<\frac{\varepsilon }{2}} <\varepsilon .
We can choose ##\varepsilon ## arbitrarily small, so (by the non-negativity norm):
0\leq \lim_{\varepsilon \to 0}\|v-w\| =\|v-w\| \leq \lim_{\varepsilon \to 0}\varepsilon = 0
Last but not least, we apply another axiom of the norm and conclude:
\|v-w\|=0 \Longrightarrow v-w=0 \Longrightarrow v=w.
This altogether means that the axioms (= definition) of the norm guarantee, that the limit definition ##\displaystyle{\lim_{n \to \infty}v_n}=v## via the norm is uniquely defined, i.e. the limit is well-defined.
Proofs are always structured that way:
- list what we already know
- transform this list into formulas by the definitions of the known
- prove the statement with those formulas
ohh, with epsilon like that.
to be honest, I did something similliar, way shorter ( just wrote definition ) and said that each of the limits ( like you did ) is smaller than ##\frac {\epsilon} 2## and thus the sum of two is smaller than epsilon.
The question is the max needed? I did without max, just took another ##n##
But ahh I see, i guess I needed to elaborate more in my answer, I did really just 3 lines of definition proof.
Thank you very much, now I understand!
fresh_42 said:
I assume that the above exercise is part of Legendre's proof of Dirichlet's theorem, which by the way seems to be rather complicated:
The problem was first formulated in full by Adrien-Marie Legendre in 1798. This was linked to a first attempt of a proof. In the second edition of his book "Essai sur la théorie des nombres" (published in 1808) he gave an erroneous proof. In the third edition of 1830 he repeated the same mistake. Legendre's error lay behind the words "As you can easily see..." appearing at the end of Section 409 of the third edition.
So much to "pretty obvious". I remember that an "obvious" took me an entire day and three variable transformations until it was obvious to me, too. Yes, it was pretty obvious. But only to either incredibly gifted persons or to those who did the handcraft dozens of times before.
  • Wow
Likes physics1000
oh by the limit is obvious, I mean regarding the limit of norm is equal to 0 if and if only the sub itself is zero. not the other thing, or you talked about it too, hehe.
anyway, thank you very much for staying in patience with me :)
Likes fresh_42
A nice result to have : A sequence in a Hausdorff space can converge to only one limit.
A norm || .|| gives rise to a metric d(x,y):= || x-y|| , so that this satisfies the Hausdorff condition
Also,
If your metric d(x,y) arises from a norm then d is translation invariant, so that d(x+a,y+a)=d(x,y) for all a, and homogeneous, i.e., d(cx,cy)=cd(x,y). Then you recover the norm || .|| by ||x||:=d(x,0)
Likes physics1000 and fresh_42
Also,
Wow, its way above my study :\
Its a course in fourier series.
but thanks :)
Likes WWGD
but thanks :)
Don't let it intimidate you. I may have written it somewhat unclearly.
Likes physics1000
physics1000 said:
Homework Statement: I wrote below what is my question exactly, no need for answer, the question is not explainable well.
Relevant Equations: no equations here. only defintion, which we have not learned and I dont know what norm they want...
The question is:
so $v=w$
$$ _always_ works. you just need enough of it ;).
So it is like duck tape.
Likes WWGD
FAQ: V Space With Norm $||*||$ - Fourier Series
What is "V Space With Norm $||*||$ - Fourier Series"?
"V Space With Norm $||*||$ - Fourier Series" refers to a mathematical concept that combines the concepts of vector spaces and norms with the study of Fourier series. It involves representing a function as a linear combination of trigonometric functions, which can be used to approximate the function in a given interval.
What is the significance of using the norm $||*||$ in this context?
The norm $||*||$ in "V Space With Norm $||*||$ - Fourier Series" is used to measure the magnitude or size of a vector. In the context of Fourier series, it is used to measure the distance between a function and its approximation, allowing for a more accurate representation of the function.
How is "V Space With Norm $||*||$ - Fourier Series" applied in real-world situations?
"V Space With Norm $||*||$ - Fourier Series" has various applications in fields such as engineering, physics, and signal processing. It is used to analyze and approximate periodic functions, which are commonly found in real-world phenomena such as sound waves, electrical signals, and vibrations.
What are the advantages of using "V Space With Norm $||*||$ - Fourier Series" over other methods of approximating functions?
Compared to other methods, "V Space With Norm $||*||$ - Fourier Series" offers a more accurate and efficient way of approximating functions. It also allows for the analysis of functions that are not continuous or differentiable, making it a more versatile tool for various applications.
Are there any limitations to using "V Space With Norm $||*||$ - Fourier Series"?
One limitation of "V Space With Norm $||*||$ - Fourier Series" is that it can only approximate periodic functions. It also requires a certain level of mathematical knowledge and understanding to apply effectively. Additionally, the accuracy of the approximation depends on the number of terms used in the series, which can be time-consuming to calculate for complex functions.
