Blimps of the Future: Vacuum-Filled Balloons & Reliable Journeys
  • Thread starter GTOM
  • Tags
    Future
In summary, the conversation discusses the possibility of using vacuum instead of hydrogen or helium to fill blimps, due to the square cube law not affecting blimps as much as helicopters. However, the disadvantages of using helium and the availability of helium are also mentioned. The idea of expanding blimp balloons electromagnetically is also brought up, but without a specific plan, it cannot be considered a realistic possibility.
GTOM
955
64
I wonder could blimps come back if they arent filled with explosive hydrogen, neither with rare helium, but simply with vacuum, the lightest substance? Theoretically its possible to expand their balloons electromagnetically.
According to TV tropes, square cube law don't affect blimps so hard as helicopters, so while they would be slow, but they could be huge and reliable.
Do you have a source discussing this?
Helium has a very low density compared to air, the difference to a vacuum is tiny. Where is the advantage? The disadvantages are huge.
There are estimations about how long until fossils, uranium depleted. Is there any estimation how much time until helium depleted? As far as i know, it is only a tiny percent of fossil gases. Or shouldn't i worry about its availability even if we needed huge amounts to fill blimps?
I don't have an exact source about expand balloons electromagnetically, but if EM fields can repel each other, is there anything prevent such use?
Practical reality? Seriously, what you are saying is just handwaving; it's backwards logic. Things are possible when demonstrated to be possible, not when "is there anything to prevent" it. If you don't have a specific idea of how this might be done, then it can't be realistically claimed to be possible.
Thread locked.
Related to Blimps of the Future: Vacuum-Filled Balloons & Reliable Journeys
1. What exactly are vacuum-filled balloons and how do they work?
Vacuum-filled balloons are a type of blimp that uses a vacuum chamber to create a low-pressure environment inside the balloon. This allows the balloon to rise and fall based on the density of the surrounding air, similar to how a hot air balloon works. The vacuum chamber is typically made of lightweight, durable materials such as carbon fiber and is powered by an electric pump.
2. What are the benefits of using vacuum-filled balloons for travel compared to traditional blimps?
Vacuum-filled balloons have several advantages over traditional blimps. They are more energy-efficient since they do not require a constant heating source like hot air balloons. They also have a longer flight range and can reach higher altitudes, making them suitable for longer journeys. Additionally, vacuum-filled balloons are quieter and emit fewer emissions, making them more environmentally friendly.
3. How reliable are vacuum-filled balloons for transportation?
Vacuum-filled balloons are designed to be highly reliable and safe for transportation. They are equipped with backup systems and emergency protocols to ensure the safety of passengers. Additionally, the use of advanced materials and technology makes them more durable and less prone to mechanical failures. However, like any form of transportation, there is always a risk, and proper maintenance and safety procedures must be followed.
4. How do vacuum-filled balloons navigate and control their movements?
Vacuum-filled balloons use a combination of GPS and onboard sensors to navigate and control their movements. The pilot can also adjust the amount of air in the vacuum chamber to control the altitude and direction of the balloon. Additionally, some models may have propulsion systems for more precise movements.
5. Are there any potential drawbacks or challenges to using vacuum-filled balloons for transportation?
While vacuum-filled balloons have many benefits, there are also some challenges and potential drawbacks to consider. They may be affected by weather conditions such as strong winds and turbulence, which could impact their flight stability. Additionally, the technology is still relatively new, and there may be regulatory hurdles and infrastructure limitations to consider for widespread use. However, with continued advancements and research, these challenges can be addressed and overcome.
  • Electromagnetism
  • Cosmology
  • Other Physics Topics
  • Astronomy and Astrophysics
  • Thermodynamics
  • Poll
  • Earth Sciences
