Vacuum energy and harmonic oscillator
In summary, the vacuum energy is related to the zero point energy of a harmonic oscillator because the quantized electromagnetic field in a cavity can be described using a harmonic oscillator Hamiltonian, which has a non-zero ground state energy. This ground state is known as the vacuum, and has the expectation value of zero for the number operator.
astrolollo
24
Hi everyone
I was wondering, why is vacuum energy related to the zero point energy of an harmonic oscillator? The hamiltonian of an harmonic oscillator is $H= \frac{p^{2}}{2m} + \frac{1}{2} \omega x^{2}$. Where does the harmonic potential term come from in the vacuum?
What do you mean by "vacuum".
The harmonic oscillator, described by the Hamiltonian,
$$\hat{H}=\frac{1}{2m} \hat{p}^2 + \frac{m \omega^2}{2} \hat{x}^2,$$
has a ground state with the energy eigenvalue ##E_0=\hbar \omega/2##, which is the lowest possible energy the oscillator can have. That energy value is ##>0##, while the lowest possible energy value of the classical harmonic oscillator is 0.
Because upon quantizing electromagnetic field in a cavity, the Hamiltonian turns out to be identical to that of a Harmonic oscillator. The eigenstates and eigenvalues of EM field's Hamiltonian can then be inferred to have the same properties as those corresponding to harmonic oscillator, where as vanhees pointed out has non-zero ground state energy. The ground state of a quantized EM field is what we termed as vacuum, this naming refers to the fact that the expectation value of number operator is zero for ground state.
Likes bhobba and vanhees71
Related to Vacuum energy and harmonic oscillator
What is vacuum energy?
Vacuum energy is a concept in quantum mechanics that refers to the lowest possible energy state that a quantum mechanical physical system can have. It is also known as zero-point energy, as it is the energy that remains even when all other forms of energy are removed from a system.
How does vacuum energy relate to the harmonic oscillator?
The harmonic oscillator is a mathematical model that describes the behavior of a physical system with a stable equilibrium point and a restoring force proportional to the displacement from that point. In quantum mechanics, the harmonic oscillator is used to study the behavior of particles in a potential energy well. Vacuum energy is present in the harmonic oscillator as it is the minimum energy state of the system, even when the oscillator is at rest.
Is vacuum energy measurable?
Yes, vacuum energy is measurable indirectly through its effects on physical systems. One way to measure vacuum energy is through the Casimir effect, where the vacuum energy between two parallel plates causes them to be attracted to each other. However, directly measuring the absolute value of vacuum energy is not currently possible.
What is the significance of vacuum energy in cosmology?
In cosmology, vacuum energy is believed to play a role in the expansion of the universe. The concept of dark energy, which is responsible for the accelerating expansion of the universe, is often attributed to vacuum energy. However, the exact nature and properties of vacuum energy are still not fully understood and remain a topic of ongoing scientific research.
Can vacuum energy be harnessed for practical use?
Currently, there is no known way to harness vacuum energy for practical use. However, some scientists are researching ways to potentially harvest vacuum energy in the future, such as through the use of quantum vacuum thrusters. However, more research and development is needed before vacuum energy can be effectively harnessed for practical purposes.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
