Vacuum Energy from Correlation Functions
masteralien
36
TL;DR Summary
In QFT the n point functions contain all the information about a QFT so how would one compute the vacuum energy just from the n point functions
In QFT the objects of interest are the n point Correlation functions which contain all the information about the theory and can be used to compute any expectation value in principle. However I cant figure out how to compute the vacuum energy from the correlation functions alone and cant find any sources or articles which discuss this computation.
Is there a way to do it with the n point functions only. I know how to compute the Vacuum Energy in QFT with the field operators but want to know how to compute it with the n point functions alone without the field operators.
The Hamiltonian density is something like
$${\cal H}=\frac{1}{2}\dot{\phi}(x) \dot{\phi}(x)+\ldots$$
Hence the vacuum energy density with the operators is
$$\frac{1}{2}\langle 0|\dot{\phi}(x) \dot{\phi}(x) |0\rangle +\ldots$$
But ##\langle 0|\dot{\phi}(x) \dot{\phi}(x) |0\rangle## is just the 2-point function
$$\langle \dot{\phi}(x) \dot{\phi}(x)\rangle = \lim_{x'\to x} \partial_0\partial'_0\langle \phi(x) \phi(x')\rangle$$
which tells you how, in principle, to compute the vacuum energy density in terms of ##n##-point functions.
I see also is it true in principle any expectation value can be computed with the n point functions
I would say any expectation value in the vacuum can be computed with the n-point functions.
What about expectation values for states which aren’t the vacuum like particle states can all those be computed with the n point functions
Also one more question can the Propagator G_2(x1-x2) be thought of as the Probability amplitude for a Particle to be found at spacetime point x1 created by a delta function source at spacetime point x2
Yes, at least in nonrelativistic QM.
FAQ: Vacuum Energy from Correlation Functions
What is vacuum energy in the context of quantum field theory?
Vacuum energy refers to the baseline energy present in empty space due to quantum fluctuations. In quantum field theory, even the vacuum state, which is devoid of particles, has fluctuating energy levels due to the Heisenberg uncertainty principle. These fluctuations lead to the creation and annihilation of virtual particle-antiparticle pairs, contributing to the so-called vacuum energy.
How are correlation functions related to vacuum energy?
Correlation functions in quantum field theory describe how field values at different points in space and time are related. They play a crucial role in calculating vacuum energy because they encapsulate information about quantum fluctuations. By evaluating these functions, one can determine the contributions of different field modes to the vacuum energy.
What methods are used to calculate vacuum energy from correlation functions?
Several methods are employed to calculate vacuum energy from correlation functions, including perturbative techniques, path integrals, and lattice field theory. Perturbative methods involve expanding around a known solution and summing contributions from various orders. Path integrals provide a way to sum over all possible field configurations. Lattice field theory discretizes space-time to make the problem numerically tractable.
What are the implications of vacuum energy for cosmology?
Vacuum energy has significant implications for cosmology, particularly in the context of dark energy and the cosmological constant. The energy density associated with the vacuum can drive the accelerated expansion of the universe, as observed in distant supernovae and cosmic microwave background radiation. Understanding vacuum energy is crucial for developing a comprehensive model of the universe's evolution.
Are there any experimental observations that support the concept of vacuum energy?
Yes, there are several experimental observations that support the concept of vacuum energy. One notable example is the Casimir effect, where two uncharged, parallel plates in a vacuum experience an attractive force due to changes in the vacuum energy between them. Additionally, the observed accelerated expansion of the universe provides indirect evidence for vacuum energy, often attributed to dark energy or the cosmological constant.
