A Vacuum Flask Thermodynamic Equation
An advanced thermodynamic equation for a vacuum flask is sought to model the cooling temperature of a liquid over time, focusing on the cylindrical center region while ignoring heat loss from the cap and bottom. Key parameters needed include reflectivity, emissivity, gas pressure in the gap, and the specific heat of the flask walls. The discussion emphasizes the importance of accurate modeling for potential design improvements or academic projects. The requester has marked the thread as advanced, indicating a desire for a graduate-level analysis. Further clarification on the purpose of the modeling and the requester's background in mechanical engineering and thermodynamics is encouraged.
Petersenwill36
Im trying to find an advanced thermodynamic equation for a vacuum flask.
I am looking for an equation to find the temperature of a liquid at time t as it cools down. Ignore the cap and bottom section; assume there is no heat loss in those areas. I'm just interested in the cylindrical center region. I need all parameters such as reflectivity, emmisivity, gas pressure in the gap and the specific heat/properties of the walls as well as any other relevant parameters. I assume the length L doesn't matter. Can't seem to find this online.
Thank you in advance.
Science news on Phys.org
See "Dewar."
Welcome to PF.
Can you say more about why you want to do this modeling? Are you wanting to design a better dewar structure, so you want to be able to model the structures as accurately as possible? Or is this maybe for a shoolwork project?
What is your background in ME and Thermo? You've marked this thread with an "A" Advanced prefix, which means that you want the discussion to be at the graduate school and PhD level.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
