Vacuum fluctuations and temperature
In summary, the conversation explores the concept of temperature in relation to quantum field theory and vacuum fluctuations. There is a discussion about whether temperature can be derived from the theory rather than introduced by hand and how it may be related to the Unruh effect. Some speculation is also presented about the possibility of a physical meaning to "imaginary time" and how the Unruh temperature could be transformed in an inertial frame. However, these ideas are considered to be controversial and not well understood by experts in quantum field theory.
tom.stoer
172
Usually when studying thermodynamics and statistical mechanics of a macroscopic body one uses a "heat bath model" to define a temperature. In quantum mechanics one can assume that the heat bath has arbitrary low temperature.
When studying quantum electrodynamics one has vacuum fluctuations of the electromagnetic field (we know from the Casimir effect that these may have measurable consequences).
Is it possible and does it make sense to introduce a kind of "heat bath generated from these vacuum fluctuations"? Or ist it standard to regularize the vacuum fluctuation such that one always has T=0 in the vacuum? Does that mean that zero point energy never contributes to temperature? (like in a Fermi gas where at T=0 the energy is huge).
I do not even have a reasonable starting point; let's consider
[itex]Z = \text{tr}\,e^{-\beta H}[/itex]
Again the temperature is introduced by hand and not generated by fluctuations.
Let me ask a different question: is it possible to interpret the difference in vacuum energy density in the Casimir experiment as a difference in the temperature?
no idea?
It has been interpreted as being the result of a negative pressure gradient in vacuum, the only reference I have of Casimir effect in relation with heat bath is from those that relate the dynamical Casimir effect (converting virtual photons into real photons) http://www.nature.com/news/2011/110603/full/news.2011.346.html with the Unruh effect: the prediction that an accelerating observer will observe black-body radiation where an inertial observer would observe none and thus an Unruh temperature.
I know about these calculations. Especially the Casimir effect can be interpreted as van-der-Waals force w/o any reference to vacuum fluctuations at all (Jaffe).
I was just thinking that there could be a attempt no to introdce T by hand but to "derive" it from the theory. At least a difference in the vacuum could contribute to a difference in the temperature scale. But I haven't seen such an interpretation.
Isn't temperature necessarily related to a thermal partition function. In the sense that its really associated to an ignorance of the state of the system not arising from purely quantum effects?
So if one is doing standard QFT with real time in flat spacetime for non-accelerating observers one cannot really speak of temperature. So at least from this perspective the casimir effect isn't associated to a temperature.
For the unruh effect the additional ignorance comes from the presence of a horizon.
I think on a deep level the Unruh effect really tells us that, in order to combine GR with QM so that it we have a unified description for all observers, statistical and quantum fluctuations must some how be unified. But really this is well beyond what is need to understand the casimir effect.
I agree.
General question: is there a mathematical way to derive the partition function and let temperature emerge instead of introducing it by hand? I haven't seen such a construction, afaik T and Z are always introduced via definitions, never derived from a "deeper structure + approximation".
Would that make sense?
The derivation of the classical statistical partition function comes from considering an ensemble of possible microscopic states. So in the classical case its just related to the ignorance of which of the states is actually the real one.
At the quantum level there may be some kind of derivation along the lines you are thinking.
But I have never seen it. However I think that thermal field theory is usually assumed to be created by hand since one has to use imaginary time in order to do it.
I think also such a derivation would be very hard since it would really involve asking questions about states in quantum field theory very far from those considered by particle physics. The beauty of physics is one does not have to go from one approximation to another in a mathematically rigours way. One can just write down a particular formalism which captures the physics we are interested in and then compute things. If we agree with experiment then we know the assumptions we made which led us to such a formalism, e.g. thermal equilibrium at T, were justified.
I think we agree that this could be an interesting speculation ...
Yes, one could perhaps attack the problem from the other side. Since we know that statistical and quantum fluctuations are formally related by a wick rotation perhaps there could be a physical meaning to "imaginary time". I think understanding the unruh effect in detail and how we should properly transform from an accelerating frame to an inertial one. Then we might see how the unruh temperature is transformed into some other effect in the inertial frame.
Although you would think this is well understood by atleast some experts in QFT i don't think it can be since it is related so closely to qft in desitter space and the black hole paradox. Both of these are controversial subjects.
Related to Vacuum fluctuations and temperature
What are vacuum fluctuations?
Vacuum fluctuations, also known as quantum fluctuations, are spontaneous changes in the energy of a vacuum. In quantum physics, the vacuum is not truly empty, but rather contains a constantly changing, fluctuating energy that arises from the uncertainty principle.
How do vacuum fluctuations affect temperature?
Vacuum fluctuations contribute to the overall energy of a system, which in turn affects its temperature. This is because temperature is a measure of the average kinetic energy of particles in a system, including the energy of vacuum fluctuations.
How are vacuum fluctuations related to the uncertainty principle?
The uncertainty principle states that it is impossible to know both the exact position and momentum of a particle at the same time. Vacuum fluctuations arise from this principle, as particles can briefly appear and disappear in the vacuum, creating fluctuations in energy.
Do vacuum fluctuations only occur at very small scales?
While vacuum fluctuations are most noticeable at the quantum level, they can also occur on larger scales. In fact, they play a role in the behavior of black holes and the expansion of the universe.
Can vacuum fluctuations be observed directly?
No, vacuum fluctuations cannot be observed directly. They are a fundamental aspect of the quantum world and can only be indirectly observed through their effects on other particles and systems.
10K
  • Beyond the Standard Models
