joniverson
I am making a device like this for the purpose of freeze drying insects. I am basically following along the same guidelines as the author. However, I am wondering about something. For his aspirator valve, he elected to save costs and use what I believe is a brass or copper 1/4" valve like is used for plumbing purposes. Since I assume the valve has threaded female inserts, he is then taking most likely a copper or brass threaded nipple pipe of appropriate length, cutting it in half, and then threading each pipe into each female side of the valve. All well and good except he doesn't discuss what adhesive/ cement, etc to use with the valve-pipe coupling. Since this part of the system will be in the freezer, along with the jar, for over a month while the freeze drying occurs, and needing to maintain 15mm Hg, I'm wondering what substance should be used on the nipple threads when screwed into the valve? I can't think something as simple as teflon tape wrapped around nipple threads before screwing in would be sufficient.
Thank you!
Thank you!
