Valence of the Lanthanides and Actinides
  • Thread starter Thread starter Thytanium
The discussion centers on the placement of valence electrons in the 4f orbitals for lanthanides and actinides, rather than in the outermost shells like 5s, 5p, or 6s. It explains that the order of orbital filling is determined by the energy levels associated with the principal (n) and secondary (l) quantum numbers. The filling sequence prioritizes lower energy orbitals, which are closer to the nucleus. The sum of these quantum numbers influences the energy levels, with higher sums indicating higher energy and thus easier ionization. The conversation emphasizes that the filling order is not strictly sequential by principal quantum number but rather based on energy considerations. A participant expresses gratitude for the clear explanation, noting that previous searches for answers were unfruitful.
Thytanium
TL;DR Summary
Lanthanides and actinides generally have valence +3 but these valence electrons I understand are in the 4f orbital but the orbitals of the outer shells: 5s, 5p, 5d and 6s for Lanthanides also have electrons that I think should be valence electrons.
My question is: Why in the Lanthanides and Actinides the valence electrons +3 are in the 4f orbitals and not in the orbitals of the outermost shells for Lanthanides: 5s, 5p, 5d and 6s because the latter would be further away from the atomic nucleus . Something similar happens for the actinides
Chemistry news on Phys.org
The orbitals are filled in order of the energy levels which is determined by two things - the n and the l quantum numbers, also called the principal and secondary quantum numbers, with the principal, n, being the shell name. The value of n goes 1, 2, 3, 4, 5, etc, while the value of l goes 0, 1, 2, 3, 4 etc and are given a letter value s, p, d, f, etc to be easier to say out loud. So for example 3p orbital has 3 as the principal quantum number and p as the secondary quantum number l which means its value is 1. The sum of these two gives the order in which they are filled, the lowest ones first.
The order is, therefore, with the lowest energy first (lowest energy ones are held closer to the nucleus, in simply terms)
1s, 2s, 2p, 3s, 3p, 4s, 3d, 4p, 5s, 4d, 5p, 6s, 4f, 5d, 6p, 7s, 5f, 6d, 7p, 8s
Because the sum of these two quantum numbers is thus
1s (1+0), 2s (2+0), 2p (2+1), 3s (3+0), 3p (3+1), 4s (4+0), 3d (3+2), 4p (4+1), 5s (5+0), 4d (4+2), 5p (5+1), 6s (6+0), 4f (4+3), 5d (5+2), 6p (6+1), 7s (7+0), 5f (5+3), 6d (6+2), 7p (7+1), 8s (8+0).
There is the additional guide that the principal quantum number is a bit more important in determining the total energy of an orbital.
eg 2p sum n+l = 3, 3s sum = 3, so 3s is higher in energy than 2p
and 5s sum = 5, but 4d sum= 6, so 4d is higher energy than 5s
and 6s sum = 6 but 4f sum = 7 so 4f is higher in energy. But while 5d sum=7 , the principal n =5 for 5d trumps the other two orbitals.
The higher energy ones are easiest to ionise, they are the valence electrons, and are farther from the nucleus. They need less extra energy to be removed than the ones close to the nucleus.
It's NOT simply all the 1 levels, then all the 2 levels, then all the 3 levels, then all the 4 levels, then all the 5 levels as you are currently suggesting.
Now to give a more detailed explanation than this takes a year or two at university. And I don't have the time to go through that size of an explanation.
Likes berkeman and Thytanium
Thank you DrJhon for such an extraordinary explanation. You have cleared all my doubts. Grateful for the time you have given me in your explanation. I had searched in chemistry books and on the Web for more than a month with no results. Thanks again. I wish you a good day. Many greetings. I really appreciate this attention with me DrJhon.
Likes berkeman and Tom.G
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
