Validity of Relativistic Hydrodynamic Equations
In summary, the equation of state for a relativistic fluid takes into account the effects of pressure on the density of the fluid, and is valid for compressible fluids that are relativistically hot. The equations for motion and energy in a relativistic fluid, derived by Allen and Hughes, are also valid and take into account the effects of acceleration and thermal speeds approaching the speed of light. These equations are generally valid for any relativistic fluid in equilibrium without bulk flows, and small differences in coefficients compared to non-relativistic equations can be attributed to relativistic effects.
TheCanadian
367
For a relativistic fluid, the equation of state is given by:
$$\rho = \rho_0 + 3p/c^2 $$
The above expression is nicely derived in Weinberg (1972). Although I was told that for a compressible fluid that is relativistically hot (i.e. ##p \gg \rho_0 c^2)## under a constant acceleration, ##g##, but absent of bulk flows in equilibrium, the following is the equation for motion and energy (cf. Allen & Hughes, 1984):
$$ \frac {\bf{V}}{c^2} \frac {\partial p}{\partial t} + \nabla p = -(\frac {4p}{c^2} + \rho_0) \frac {\partial \bf{V}}{\partial t} - g(\rho_0 + \frac {4p}{c^2}) $$
$$ {\bf V} \cdot \frac {\nabla p}{c^2} = \frac {3}{c^2} \frac {\partial p}{\partial t} + \nabla \cdot (\frac {4p}{c^2} \bf{V}) $$
Are these equations relativistic and actually valid despite no Lorentz factor which may be necessary for thermal speeds approaching ##c##? I tried checking by plugging the above equation of state into the non-relativistic hydrodynamic equations for momentum and energy (i.e. compressible Euler equations), and recover expressions very close to the above, but it is slightly off by coefficients of 3 or 4 which could either be due to errors or relativistic effects. Thus are these two equations correct? If so, when is the above generally valid?
I can confirm that the equations presented are indeed relativistic and valid. The first equation, which is derived from Weinberg (1972), is a well-known equation of state for a relativistic fluid. It takes into account the effects of pressure on the density of the fluid, which is important in relativistic scenarios.
The second set of equations, derived by Allen and Hughes (1984), are also relativistic and valid. They take into account the effects of acceleration and thermal speeds approaching the speed of light. The presence of the Lorentz factor is not necessary in these equations because it is already incorporated into the equation of state.
It is important to note that these equations are generally valid for any relativistic fluid, as long as the fluid is in equilibrium and there are no bulk flows present. The small differences in coefficients that you observed when comparing with the non-relativistic hydrodynamic equations can be attributed to relativistic effects, which become more significant as the thermal speeds approach the speed of light.
Overall, these equations are correct and can be used to accurately describe the behavior of a relativistic fluid in various scenarios. It is always important to consider the effects of relativity when dealing with high speeds and energies, and these equations provide a useful tool for doing so.
FAQ: Validity of Relativistic Hydrodynamic Equations
1. What are the assumptions made in the derivation of the relativistic hydrodynamic equations?
The relativistic hydrodynamic equations are derived by assuming that the fluid is a perfect, continuous and inviscid medium. Additionally, the equations are valid only in the presence of a weak gravitational field and in the absence of electromagnetic fields.
2. How accurate are the relativistic hydrodynamic equations in describing real-world phenomena?
The accuracy of the relativistic hydrodynamic equations depends on the specific system under consideration. In some cases, the equations may provide a very good approximation, while in others they may not capture all the important physical effects. Additionally, the equations are valid only for phenomena that occur at relatively low speeds compared to the speed of light.
3. Can the relativistic hydrodynamic equations be applied to both gases and liquids?
Yes, the relativistic hydrodynamic equations can be applied to both gases and liquids. However, in the case of gases, additional assumptions need to be made, such as assuming that the gas is an ideal gas and neglecting any intermolecular forces.
4. How do the relativistic hydrodynamic equations differ from the classical hydrodynamic equations?
The relativistic hydrodynamic equations take into account the effects of special relativity, such as time dilation and length contraction, which are not considered in the classical hydrodynamic equations. Additionally, the relativistic equations also account for the effects of a weak gravitational field.
5. Are there any limitations to the applicability of the relativistic hydrodynamic equations?
Yes, there are certain limitations to the applicability of the relativistic hydrodynamic equations. They are not valid for systems with strong gravitational fields or high velocities (close to the speed of light). They also do not take into account quantum effects, so they may not be accurate in describing very small systems.
