Value of an expression involving complex numbers
In summary, the conversation discusses how to evaluate the complex function X = 3^(3 + (8pi)/ln(3)i) and the steps involved in converting it to a number. The solution involves using Euler's identity and taking logarithms to simplify the expression, resulting in the final answer of 27.
Uniman
The answer is a number...
Work done so far
3^3 * 3^( i8pi/ln(3) ) = 27 * (3^ i8pi - 3^ln(3) ) = 27 *( 3^25.1i -3.34)
= 3^(3+ i25.1) - 90.26
If this is correct how can I convert this to a number...
Re: Complex function
Uniman said:
https://www.physicsforums.com/attachments/423
Work done so far
You can use Euler's identity to 'discover' that is...
$\displaystyle 3^{3 + i\ \frac{8\ \pi}{\ln 3}}= e^{3\ \ln 3}= 27$
Kind regards
$\chi$ $\sigma$
Hello, Uniman!
[tex]\text{Evaluate: }\:X \;=\;3^{3 + \frac{8\pi}{\ln(3)}i}[/tex]
We have: .[tex]X \;=\;3^3\cdot3^{\frac{8\pi}{\ln(3)}i} \;=\;27\cdot 3^{\frac{8\pi}{\ln(3)}i} [/tex] .[1]
[tex]\text{Let }y \:=\:3^{\frac{8\pi}{\ln(3)}i} [/tex]
[tex]\text{Take logs: }\:\ln(y) \;=\;\ln\left(3^{\frac{8\pi}{\ln(3)}i}\right) \;=\;\frac{8\pi}{\ln(3)}i\cdot\ln(3) \;=\;8\pi i[/tex]
. . [tex]y \;=\;e^{8\pi i} \;=\;\left(e^{i\pi}\right)^8 \;=\;(\text{-}1)^8 \;=\;1[/tex]Substitute into [1]: .[tex]X \;=\;27\cdot1 \;=\;\boxed{27}[/tex]
FAQ: Value of an expression involving complex numbers
What are complex numbers?
Complex numbers are numbers that consist of a real part and an imaginary part. They are written in the form a + bi, where a is the real part and bi is the imaginary part with i being the square root of -1.
What is the value of an expression involving complex numbers?
The value of an expression involving complex numbers is a complex number itself. It is determined by performing operations on the real and imaginary parts of the complex numbers in the expression.
How are complex numbers used in science?
Complex numbers are used in various fields of science, such as physics, engineering, and mathematics. They are particularly useful in solving problems that involve wave phenomena, such as electromagnetism and quantum mechanics.
Can complex numbers have a negative real part?
Yes, complex numbers can have a negative real part. The real part can be positive, negative, or zero, while the imaginary part can also be positive, negative, or zero.
How do you calculate the absolute value of a complex number?
The absolute value of a complex number is calculated by taking the square root of the sum of the squares of its real and imaginary parts. In other words, it is the distance of the complex number from the origin on a complex plane.
