MHB Value of $\dfrac{2k^2}{k-1}$: Solving the Equation
anemone
MHB
POTW Director
Determine the value of $\dfrac{2k^2}{k-1}$ given $\dfrac{k^2}{k-1}=k^2-8$.
Mathematics news on Phys.org
Solution of other:
Rewrite the given equation as a cubic equation, we see that:
$k^3-2k^2-8k+8=0$
Let $k=\dfrac{2+4\sqrt{7}x}{3}$, the above cubic equation becomes $4x^4-3x=-\dfrac{1}{2\sqrt{7}}$.
Let $x=\cos \theta$, $4x^4-3x=-\dfrac{1}{2\sqrt{7}}$ translates into $\cos 3\theta=-\dfrac{1}{2\sqrt{7}}$ and this gives
$x=\cos\left(\dfrac{1}{3}\arccos \left(-\dfrac{1}{2\sqrt{7}}\right)+\dfrac{2n\pi}{3}\right)$, where $n\in\{0,\,1,\,2\}$
So
$\dfrac{2k^2}{k-1}=\dfrac{8(28\cos^2\left(\dfrac{1}{3}\arccos \left(-\dfrac{1}{2\sqrt{7}}\right)+\dfrac{2n\pi}{3}\right)+4\sqrt{7}\cos \left(\dfrac{1}{3}\arccos \left(-\dfrac{1}{2\sqrt{7}}\right)+\dfrac{2n\pi}{3}\right)+1}{3\left(4\sqrt{7}\cos \left(\dfrac{1}{3}\arccos \left(-\dfrac{1}{2\sqrt{7}}\right)+\dfrac{2n\pi}{3}\right)-1 \right)}$,
Compute the value of the targeted expression with calculator, by first taking $n=0$ and then replace it by $n=1$ and next $n=2$ we get three different values for $\dfrac{2k^2}{k-1}$:
$9.9758,\,-3.5603,\,-14.4155$
we have :$k^3-2k^2-8k+8=0-----(1)$
to find the solution of (1) we can use Newton's method
the roots of (1)
$k=-2.494, 0.8901, 3.609$
$\therefore \dfrac {2k^2}{k-1}=-3.56041,-14.4182, 9.975879$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
