issacnewton
- 1,016
- 35
For what values of c is there a straight line that intersects the curve ##y = x^4+c x^3+12x^2-5x+2## in four distinct points ?
Concept of concavity, Vieta's formulas (link)
Suppose a straight line ##y = mx+b## intersects this curve. Then to find the points of intersection, we equate the two. ##x^4+c x^3+12x^2-5x+2 = mx+b##. This leads to ##x^4+c x^3+12x^2-5x+2 - mx-b = 0##. Now this is a polynomial of degree 4. If the line intersects the curve in 4 distinct points, then above equation has 4 distinct roots. Let ##r_1,r_2,r_3,r_4## be 4 distinct roots of this polynomial. Now we use Vieta's formulas, which give the relationship between the coefficients of a polynomials and its roots. For a polynomial of degree 4, we get ##r_1+r_2+r_3+r_4 = -c## and ##r_1r_2 + r_2r_3 + r_3r_4+r_4r_1+ r_2r_4 + r_3r_1 = 12##. Since roots are distinct, we have ##\sum\limits_{i>j}~ (r_i - r_j)^2 > 0##. Now expanding this sum leads to $$3\sum_i r_i^2 - 2\sum_{i>j} r_i r_j > 0\cdots\cdots (1)$$ Now squaring of ##r_1+r_2+r_3+r_4 = -c## leads to the following $$\sum_i r_i^2 + 2\sum_{i>j} r_i r_j = c^2 \cdots\cdots (2)$$ Its been given to us that ##\sum\limits_{i>j}r_i r_j = 12##. Plugging this in equation ##(2)##, we get $$\sum_i r_i^2 = c^2 - 24 \cdots\cdots (3)$$ And plugging this in equation ##(1)##, we get $$3(c^2 - 24)-2(12) > 0$$ This leads us to inequality, ##c^2 > 32##. So we have ##|c| > 4\sqrt{2}##. So this must be true for the line to have 4 intersects with this curve. There is another approach using the concept of concavity from Calculus. I argue that if a line is to intersect this curve at 4 distinct points, then the curve changes the concavity at two distinct points. This means that the curve has two inflection points. This further means that if ##y = f(x)##, then ##f''(x) = 0## has two distinct roots. Now ##f''(x) = 0## leads to ##2x^2+cx+4 = 0##. Since there are two distinct roots, the discriminant must be positive. This again leads to ##c^2 > 32##, which is ##|c| > 4\sqrt{2}##.
Do you think the solution is correct ?
Thanks
