MHB Vanishing wronskian for linearly independent solutions
The discussion revolves around verifying the linear independence of the functions \( y_1 = x^3 \) and \( y_2 = |x|^3 \) as solutions to the differential equation \( x^2y'' - 4xy' + 6y = 0 \). It is noted that the Wronskian \( W(y_1, y_2) = 0 \) for all \( x \), which suggests linear dependence, contradicting the initial assumption of independence. The issue arises because the coefficient \( a_2(x) = x^2 \) becomes zero at \( x = 0 \), violating a condition of the linear independence theorem. The conversation also emphasizes that proving \( c_1 = c_2 = 0 \) for all \( x \) is unnecessary; checking specific values suffices to establish independence. Ultimately, the participants clarify that the functions are indeed linearly independent despite the zero Wronskian due to the nature of the functions involved.
issacnewton
Hi I am trying to do this problem. Verify that \( y_1=x^3 \) and \(y_2=|x|^3 \) are linearly independent solutions of the diff. equation
\( x^2y''-4xy'+6y=0\) on the interval \((-\infty,\infty) \). Show that \( W(y_1,y_2)=0 \) for every real number x.
I could actually show the above by splitting the interval for \( x>0 \) ,\( x=0 \) and \( x<0 \). Now there is theorem about the wronskian. The set of
solutions \(y_1,y_2,\cdots,y_n \) is linearly independent on \( I\) iff \( W(y_1,y_2,\cdots,y_n)\neq 0 \) for every x in the interval. But in this problem,
\( W(y_1,y_2)=0 \) for every real number x. So the reason for this is that , we have \( a_2(x)=x^2 \) , which is zero when x=0 in the given interval. So
one of the conditions for the theorem is not satisfied here. Thats why we get weird behavior here. Is my reasoning correct ?
Thanks
I don't think you need to split the interval into three pieces. Just differentiate your functions there (note that $d|x|/dx=\text{sgn}(x)=x/|x|=|x|/x$) and plug them into the DE. As for linear independence, I think you might be able to do that from the definition.
ackbach, on second look at my work I see that I have not really done the problem correctly. I tried to use the approach suggested by you in the second line. But for \( y_2=|x|^3 \), when I plug this into the diff. equation, the second derivative of \(y_2 \) gives second derivative of \( |x| \), which doesn't cancel out, so I don't get zero . As for linear independence, consider the equation \( c_1 x^3 + c_2 |x|^3=0 \). How do I show that
\( c_1=c_2=0 \). ?
Hmm. Let me see here. We have the following:
\begin{align*}
y_{2}&=|x|^{3}\\
y_{2}'&=3|x|^{2}\,\frac{x}{|x|}=3x|x|,\quad\text{ for }x\not=0\\
y_{2}''&=3\left(|x|+x\,\frac{|x|}{x}\right)=6|x|.
\end{align*}
You can see here that I'm using whichever form of $d|x|/dx$ I want for convenience. Also note that the function is not differentiable at the origin. Plugging this into the DE yields
$$x^{2}(6|x|)-4x(3x|x|)+6|x|^{3}=-6x^{2}|x|+6|x|^{3}.$$
What can you say about this expression? Don't forget that $|x|\equiv\sqrt{x^{2}}$.
As for linear independence, plug in, say, $x=1$ to get one equation, and $x=-1$ to get another. Solve.
thanks for detailed explanation. About the constants c1 and c2 , I have a question. Why did you choose particular values of x to solve for them. We need to prove that \(c_1=c_2=0\) for all
x in \((-\infty,\infty) \).
Hmm. Well, that's a good question. The definition of linearly dependent functions, according to MathWorld, is that two functions $f_{1}$ and $f_{2}$ are linearly dependent on $\mathbb{R}$ if there exists $c_{1}, c_{2}$, not both zero, such that $c_{1}f_{1}(x)+c_{2}f_{2}(x)=0$ for all $x\in\mathbb{R}$. We could write that in first-order logic as:
$((\exists c_{1})(\exists c_{2})(\forall x\in\mathbb{R})[((c_{1}\not=0)\lor(c_{2}\not=0)) \land (c_{1}f_{1}(x)+c_{2}f_{2}(x)=0)]\implies f_{1}\text{ and }f_{2}\text{ are linearly dependent.}$
The contrapositive gives us the definition of linearly independent functions:
$f_{1}\text{ and }f_{2}\text{ are linearly independent }\implies \lnot \left\{(\exists c_{1})(\exists c_{2})(\forall x\in\mathbb{R})[((c_{1}\not=0)\lor(c_{2}\not=0)) \land (c_{1}f_{1}(x)+c_{2}f_{2}(x)=0)]\right\}$
or
$f_{1}\text{ and }f_{2}\text{ are linearly independent }\implies (\forall c_{1})\lnot \left\{(\exists c_{2})(\forall x\in\mathbb{R})[((c_{1}\not=0)\lor(c_{2}\not=0)) \land (c_{1}f_{1}(x)+c_{2}f_{2}(x)=0)]\right\}$
or
$f_{1}\text{ and }f_{2}\text{ are linearly independent }\implies (\forall c_{1})(\forall c_{2})\lnot \left\{(\forall x\in\mathbb{R})[((c_{1}\not=0)\lor(c_{2}\not=0)) \land (c_{1}f_{1}(x)+c_{2}f_{2}(x)=0)]\right\}$
or
$f_{1}\text{ and }f_{2}\text{ are linearly independent }\implies (\forall c_{1})(\forall c_{2})(\exists x\in\mathbb{R})\lnot \left\{[((c_{1}\not=0)\lor(c_{2}\not=0)) \land (c_{1}f_{1}(x)+c_{2}f_{2}(x)=0)]\right\}$
or
$f_{1}\text{ and }f_{2}\text{ are linearly independent }\implies (\forall c_{1})(\forall c_{2})(\exists x\in\mathbb{R})[\lnot((c_{1}\not=0)\lor(c_{2}\not=0)) \lor (c_{1}f_{1}(x)+c_{2}f_{2}(x)\not=0)]$
or
$f_{1}\text{ and }f_{2}\text{ are linearly independent }\implies (\forall c_{1})(\forall c_{2})(\exists x\in\mathbb{R})[((c_{1}=0) \land (c_{2}=0)) \lor (c_{1}f_{1}(x)+c_{2}f_{2}(x)\not=0)].$
So what this is saying is that either $c_{1}=0$ and $c_{2}=0$, or the linear combination is not zero. Clearly, both cannot be true simultaneously. But you can see here, that because of the negation, the $\forall$ quantifier in the definition of linear dependence becomes the $\exists$ quantifier after negation for the definition of linear independence. So I don't need to prove this is true for all $x$.
When it comes to two functions, all you need to do is see if one of the functions is a constant multiple of the other. If they are, then they're linearly dependent. If they're not, then they're linearly independent.
  • · Replies 23 ·
